D21 drawbar slop. |
whatscooking
Topic: D21 drawbar slop.Posted: 6 hours 52 minutes ago at 3:18am |
The large roller has quite the flat spot, it looks to made out of cast iorn, not advable,will haft to weld. The other piece is worn also.
Anything wrong with a suitable strap underneath the drawbar bolted to the existing hitch to tighten things up, the strap would need to be notched i suppose to allow for some twisting. Has got to be better than letting that bang around. Looking for ideas. Edited by whatscooking - 6 hours 8 minutes ago at 4:02am |
68 D21 81 7060
Posted: 3 hours 47 minutes ago at 6:23am |
3/4" inch thick strap minimum. Pull the drawbar up tight against the bail. Use locknuts and grade 8 bolts so nothing ever shakes loose. Probably slip a thin strap (of the correct thickness) under the roller for the gr 8 bolts to go thru and keep all the slop out of everything. Whatever you do will be better than OEM. All drawbar engineers wanted you to be able to easily position the drawbar to the right or left or free-swinging. The reality of row-crop tractors is we just leave it in the middle, so why not secure it solid ??
Edited by DrAllis - 1 hour 42 minutes ago at 8:28am |
whatscooking
Posted: 1 hour 1 minutes ago at 9:09am |
If I understand your description why does the roller still need to be there, saftey net?
68 D21 81 7060
Posted: 47 minutes ago at 9:23am |
It really doesn't need to be there. Just maybe makes it look a bit more original, but that's up to you.
