3-Point Arms Stuck?
Derricks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Topic: 3-Point Arms Stuck?
    Posted: 10 Oct 2026 at 4:27pm
I've got a D17 Series IV that's got 3-point arms that don't want to move.
All of the levers are moving (I sprayed some lubricant to really free them), and some will make some noises...but the 3-point arms don't want to move.
I believe I'm supposed to put both of the rear levers (traction control) to the forward position, then the farthest right lever in the front (set of 3) is the one that should control the 3-point arms (up and down). I move that lever forward and back while stepping/jumping on the 3-point arms and they aren't moving.
Any ideas?
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:37pm
Believe the short lever on the left is to go foward
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:39pm
Believe the short lever on the left is to go foward, position control. And ya got to force the arms down.
Edited by whatscooking - 10 Oct 2026 at 5:40pm
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:55pm
What does the operators manual say? You may have the levers moving but not the valve spool itself.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 7:05pm
On the front right lever witch is the main three point hitch control you should be able to feel the detents as you move it
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 5:53am
I assume the arms go up when the tractor is running and lower when the engine is off.
If all your linkages are moving and not worn excessively, refer to your picture between the hydraulic cylinder and the Position / Traction levers. On the cap with Allen head bolts holding the cap, behind the hydraulic arms lever (nearest the fender), remove the two Allen screws and remove the cap. Spray a little light oil on the plunger, then use a punch and tap the plunger forward. You may have to do it a few times until it moves easily.
Edited by WF owner - 11 Oct 2026 at 5:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 9:08am
Both rear levers should be pushed forward to the front of the tractor.  If that doesn't help, your linkage under the console is seized up.  There are 2 or 3 pivot points under there that should move freely by hand.  If any of them are stuck, you will have the problem you currently have.  You have to get under there and lubricate them good so they move freely.  It's a common problem after 60 years without lubrication.  The traction booster could also be stuck, but from my experience, 90% of the time the linkage is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 9:44am
DID you just buy this tractor ?? and the arms were already up ??   I would approach this a little differently. I think your cylinders are STUCK in the extended position from being left there for years. Disconnect the hyd hoses on each cylinder. Use a 8 or 10 foot pipe to try and pry the arms down. I'll bet you'll wind using a chain wrapped around the top and a tractor to jerk them downward.  If you get them down, reconnect hoses and if they raise back up on their own, you do have a linkage problem. My point is those arms don't always drop down from their own weight.....They just don't especially if they are stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 11:34am
It sat for about 12 years with the arms in that position...so I'm sure that's not helping anything.
I lubricated the linkage on the levers and from what I can see, they're all freely moving and pushing/pulling what they should be.
The 3-point arms just don't want to go down. I appreciate the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 1:05pm
Ive got a 8070 that does the same thing. I take a comealong and hook to the arms and go under the drawbar and pull them down. After they start moving it works fine. Ive sprayed around the rockshaft with penetrant and i think that helps some but it still sticks sometimes
1984 80780
1957 D14
616 tractor
DAC9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAC9 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 1:58pm
I have the same issue with a D17 Series 4 I purchased. It appeared the lift arms were up, hydraulic cylinders extended, for a long time prior to my ownership. I decided to remove the cylinders and have a local shop ensure they work properly. They had a hard time getting the frozen cylinders to retract. Putting the repaired cylinders back on the tractor helped the issue. The lift arms will go down. Unfortunately, if they are left up long enough (maybe a few months) more than a couple hundred pounds is needed to encourage them to go down. I have also lubricated everything I can see to be a moving part within the linkage, including the plunger under the cap secured by allen screws. I would definitely confirm the cylinders are not frozen in the extended position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:21pm
I appreciate all of the suggestions!
I managed to wrestle a rear 3-point blade on with the arms stuck where they are. With the added weight, plus cranking downward with my comealong, unfortunately the 3-point arms are still stuck.
I'll pop off the cover for the valve on the right next, hoping that the float inside is stuck and that's the problem.
If anybody has any other recommendations, I'm all ears!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:27pm
Crack the hoses loose on the cylinders and see if oil will bleed out of the cylinders.
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 9:38pm
I agree with Lynn. Was thinking the same thing. Could have a seal failure letting oil get behind cylinder shaft. I’ve had it happen on multiple hydraulic cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2026 at 10:11pm
If you don't crack the cylinder hoses loose first, you are going about this bass-ackwards.
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 5:46am
Those are single acting cylinders take everything off the three point and crack the lines going to the cylinder as Doc says
If the lines are cracked or even undone with no weight on the three point then try to push them down by hand if they won’t go down take them off and have them redone they are probably rusted up from lack of use
The reason to remove all weight from the three point when you crack the lines is that it could be a linkage issue and don’t want anyone to get hurt if whatever is on it falls
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 6:04am
Take a 7/8" wrench and loosen just one of the connections at the base of ONE cylinder !!!   They are teed together so you only need one leak !!  Loosen it a couple of turns and if the weight of that blade doesn't start the arms to drop, the cylinders are STUCK !!!   Stand in front of the rear wheel away from the blade to keep yourself safe. This isn't a difficult test and a very accurate one at that.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 12:15pm
My CA was stuck after sitting 30 years.  Completely unmovable.  The cylinders were fine, it was the rockshaft that was rusted fast.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 8:43am
I appreciate the input, again guys!
I tried valiantly to pop the valve cover off on the right hand side underneath the levers...and the allen wrench screws were extremely stripped.
I also tried valiantly to unscrew the 7/8" nut on one of the hydraulic lines that attaches to one of the cylinders and it absolutely wouldn't budge.
I'm facing a mobile tractor repair guy coming out (with a minimum $300 charge and no guarantee it'll get working), selling and cutting my losses, or regrouping and trying some more.
There are worse things happening...she runs and drives excellently!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 8:57am
You can follow that oil line/hose up to the hydraulic valve and try to loosen the line nut at the "TEE" and accomplish the same thing. Lots of penetrating oil would be good. A little torch heat down below on that cylinder nut would break it free. The 7/8" wrench has to be a good one so it doesn't spread out and damage the nut. It will come loose. It's just a matter of attacking it correctly for however rusted tight it is. As far as those allen head bolts go, you must always get a large diameter punch and smack them hard a time or two directly on top of the bolt head with a 3 lb club or you have zero chance of getting them loose.
Edited by DrAllis - 15 Oct 2026 at 9:23am
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 9:56am
Listen to the Dr. and take hydraulic line loose anywhere you can before you go any further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2026 at 7:29am
Our 185 when we got it. The cylinder on the end of circuit was full of gunk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 9:59pm
Appreciate the help, guys!
Had a mobile mechanic come out and did the following:
1) Opened hydraulic line and fluid came out
Arms still stuck
2) Popped valve cover off and flushed out gunk and cleaned inside
Arms still stuck
3) Popped pins out from 3-point arms to detach from hydraulic cylinders
Arms dropped manually
4) Attempted to hammer/force cylinders in (while pressing “down” lever)
Cylinders didn’t budge
The conclusion is that the cylinders are seized and need to be replaced. There’s rust on one of them and the mechanic suggested to find a replacement as opposed to repairing, if possible.
Anybody have any thoughts on this? Any leads on hydraulic cylinders for a Series IV D17? Thank you!
Edited by Derricks - 1 hour 60 minutes ago at 10:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 36 minutes ago at 10:07pm
Have those fixed. Any good hydraulic cylinder shop can fix you up
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 11:12pm
I'd fix em. If outside tractor,leave collapsedto spare from rusting more. HYD shop better equipped than you to work on them. Price it all first. Replace VS rebuild.
Edited by SteveM C/IL - 1 hour 30 minutes ago at 11:13pm
This page was generated in 0.114 seconds.
