L3 Gleaner?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: L3 Gleaner?
    Posted: 1 hour 23 minutes ago at 9:33pm
Is there any way to bench test the 71313444 magnetic pickup sensor to see if it is good?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 41 minutes ago at 10:15pm
I believe that they are nothing more than just a coil of finely wound wire. It should have a specific ohm amount when checked with a meter. You can compare the reading with a known good one or even swap it to a different function to see if it works.
