Ford edge brakes
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Ford edge brakes
    Posted: 12 Oct 2026 at 3:04am
Hey guys wondering if you've ever run into something like i did this weekend.
2013 ford edge. Brakes worked great right at first but if you held them say your at a stop sign they would steadily sink to the floor and the brake holding power would go away.
Must be a bad master cylinder. Removed it which was a chore on its own. Got new master and bench bleed it with block off plugs where the lines would go. Put it together and absolutely no brakes at all. Dad comes to help and he suggested to bleed the master the old school ways with lines going from the ports back into the resvoir. Put it all together and still nothing.
Crack the lines loose at the master and use my power bleeder. Seems good. Went around to each wheel and power bled them. Still nothing. Had dad in the car pumped it up 3 times cracked each master cylinder line. No help.
Dad asked about the abs. So we did a power bleed of that using a scan tool. We then finished the night with the pump 3 times hold and I Crack the line.
None of this helped. I have no brakes at all. What could I have done wrong. I stared with a vehicle that I would be comfy going 80 in and stopping. I wouldn't have felt comfy depending on then holding after an extended period time of holding the pedal but at least it was drivable. I'm at the point I wouldn't take this over 2 miles per hour.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 5:26am
Vacuum brake booster or hose bad?
Edited by john2189 - 12 Oct 2026 at 5:27am
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 6:19am
hmm, if you can  pump the brake pedal 3-4 times , pedals high, hold, then slowly goes down tot he floor, I'd say BAD rubbers in the master cylinder. It's feeding back ,around the 'loose' rubber from the outgoing side back into the reservoir side.
I had that happen on my '57 Willys. pro brake shop ( #1 in Hamilton ) rebuilt the master cylinder, dang near killed me going down a steep hill.... anyway went to local parts store bought a NEW unit with 1/4" of dust on it.... worked 100%.
hint.... if you have ZERO leaks..the oil HAS to be going 'somewhere'..round and round the rubber , is my best guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 8:07am
Ì also thought the new master cylinder was bad. So i went and got another one with no luck
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 8:19am
This is crazy. I’m not any help at all but following. Because all I can think is that it’s gotta be something really stupid! Please keep us posted!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 9:16am
Seems like you have eliminated the master cyl and the trapped air..........
What Causes a Complete Loss of Brake Power?
If your brake pedal drops straight to the floor or you lose all stopping power, the problem is not a bad ABS. A total loss of brakes is usually caused by:
  • A ruptured or rusted-out brake fluid line (causing a severe fluid leak).
  • A failed master cylinder (which builds and holds the hydraulic pressure).
  • Large amounts of air trapped in the brake lines.
  • Stuck or leaking internal ABS isolation valves in rare instances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 9:20am
Maybe pull the ABS fuse and then test it... When you start the car, the ELECTRICIAL to the ABS is ON.. When you are pumping the pedal with engine off, NO ABS..
Yes, the ABS (Anti-lock Braking System) valves in a car are electrically controlled, even though they manage hydraulic brake fluid.
How It Works
  • Solenoid Valves: The valves inside the ABS hydraulic control unit (HCU) are solenoids (electromagnets).
  • Electrical Control: The ABS computer (ECU) sends rapid electrical signals to open, close, or hold these solenoid valves dozens of times per second when it detects a wheel locking up.
  • Hydraulic Action: While the valves themselves are triggered electrically, they control the physical flow and pressure of the hydraulic brake fluid moving to your wheels.
Edited by steve(ill) - 12 Oct 2026 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 10:39am
One other thing that comes to mind.
Push rod length? Is it possible that could be off so far to give me this trouble?
Seems odd that 2 cylinders would both be that far out of adjustment.
I. Haven't adjusted a push rod in ages.
I will give the fuse a try.
I just hate to give up but it gets to a point how much time can I afford to put into this
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 1:36pm
master cylinder and trapped air are both "old school problems"... normally an easy fix... thats why i suggest looking more into the ABS... it can have more Hidden problems.. and you apparently had some problem BEFORE you changed the Master. ... but checking the rod stroke is a good idea.. should be able to compare the OLD master to the NEW if you still have it..
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 51 minutes ago at 2:29pm
Niegbhor had 72 Chev C20 4x4 truck, the first year with front disc brakes. Somewhere around 2000 he was replacing rotors and pads on the front brakes as I stopped to visit about something. Complaining about the how hard they were to bleed. So he had gotten a power bleeder. Not many years later he retired, I bought the old pickup.  A few more years go by one of the rubber brake lines breaks. I was having trouble getting the air out. Called my friend that just has touch with repairs, always goes faster with his help. Just has much better mechanics brain than I do.  He takes one look, why do you have the bleeder valve on bottom? Never entered my mind to thing about. On that truck brake assembly fits ether side, but the bleeder hole are only drilled on one, so right and left are different. Some how the by now dead previous owner had gotten them bleed and they worked for years. But much easier to work with the earths forces and let air rise to eascape.
Maybe something you're not thinking of like me as you stare at it. I have never gotten into the ABS stuff. Please come with answer when it is fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 56 minutes ago at 6:24pm
My sisters Edge did that. Turned out to be the ABS solenoid. Like to never found one. I think just shy of a thousand dollars complete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 45 minutes ago at 6:35pm
yea, i thought to pull the fuse and turn the ABS OFF... but if the valve failed in the wrong position and leaks thru... that might not work..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 6:49am
I’d like to say that I’ve never heard of that. But I, ummm, err, uh, “know” someone who did that 🙄
