2027 Chevy truck
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: 2027 Chevy truck
    Posted: 20 Sep 2026 at 6:15am
See they won't have a engine oil dipstick
I'm not short and have to use a step stool to reach the one on my 2018 truck
Still doesn't seem like a good idea to me to eliminate it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 7:43am
for 90% of the population that never check the oil level and dont know what a dip stick is anyway... having the little idiot light that says " add oil" or "change oil" is probably a good idea..
Personally i prefer the dip stick to really tell you what you got.... Elimination of the trans dip stick was the "test" ... apparently that worked... i dont like that either.... the problem is when you CHANGE oil, exactly how much do you put back in ?  Crawling under the truck and pulling a plug on a HOT RUNNING trans is not my idea of a good time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 8:36am
Good point Steve! Salesman at the dealership told me " I bet you're one of those guys that checks his oil" Guess not many do like you said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 9:57am
but they have a computer with camera looking at the driver 24/7.......
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 11:48am
Bad idea…
Just had to replace a temperature sender on one of my dad’s older John Deere’s, said it was about to overheat as soon as someone turned on the key.
But maybe they got rid of the engine and put it to electric….
Edited by 55allis - 20 Sep 2026 at 11:48am
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 8:01pm
Worst idea ever!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 3:31am
Well at least the Warranty Sleuths cannot deny warranty when engine eats all the oil and then itself. Happens quite more often than not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 53 minutes ago at 6:39am
Just read that you have the engine at idle and pull up the oil level screen. It will say if oil is low and how much to add. What could go wrong, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 minutes ago at 7:09am
Tell me again why I should be buying a new anything instead of keeping what I have going. There's no argument whatsoever that could convince me to but this new overpriced crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 minutes ago at 7:17am
Oh Paul, you're missing out. Now I see you can opt for a little fridge under the armrest! Gotta have that!
