3-Point Arms Stuck?
Derricks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Topic: 3-Point Arms Stuck?
    Posted: 10 Oct 2026 at 4:27pm
I've got a D17 Series IV that's got 3-point arms that don't want to move.
All of the levers are moving (I sprayed some lubricant to really free them), and some will make some noises...but the 3-point arms don't want to move.
I believe I'm supposed to put both of the rear levers (traction control) to the forward position, then the farthest right lever in the front (set of 3) is the one that should control the 3-point arms (up and down). I move that lever forward and back while stepping/jumping on the 3-point arms and they aren't moving.
Any ideas?
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:37pm
Believe the short lever on the left is to go foward
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:39pm
Believe the short lever on the left is to go foward, position control. And ya got to force the arms down.
Edited by whatscooking - 10 Oct 2026 at 5:40pm
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 5:55pm
What does the operators manual say? You may have the levers moving but not the valve spool itself.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2026 at 7:05pm
On the front right lever witch is the main three point hitch control you should be able to feel the detents as you move it
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:53am
I assume the arms go up when the tractor is running and lower when the engine is off.
If all your linkages are moving and not worn excessively, refer to your picture between the hydraulic cylinder and the Position / Traction levers. On the cap with Allen head bolts holding the cap, behind the hydraulic arms lever (nearest the fender), remove the two Allen screws and remove the cap. Spray a little light oil on the plunger, then use a punch and tap the plunger forward. You may have to do it a few times until it moves easily.
Edited by WF owner - Yesterday at 5:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:08am
Both rear levers should be pushed forward to the front of the tractor.  If that doesn't help, your linkage under the console is seized up.  There are 2 or 3 pivot points under there that should move freely by hand.  If any of them are stuck, you will have the problem you currently have.  You have to get under there and lubricate them good so they move freely.  It's a common problem after 60 years without lubrication.  The traction booster could also be stuck, but from my experience, 90% of the time the linkage is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:44am
DID you just buy this tractor ?? and the arms were already up ??   I would approach this a little differently. I think your cylinders are STUCK in the extended position from being left there for years. Disconnect the hyd hoses on each cylinder. Use a 8 or 10 foot pipe to try and pry the arms down. I'll bet you'll wind using a chain wrapped around the top and a tractor to jerk them downward.  If you get them down, reconnect hoses and if they raise back up on their own, you do have a linkage problem. My point is those arms don't always drop down from their own weight.....They just don't especially if they are stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Derricks Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 26 minutes ago at 11:34am
It sat for about 12 years with the arms in that position...so I'm sure that's not helping anything.
I lubricated the linkage on the levers and from what I can see, they're all freely moving and pushing/pulling what they should be.
The 3-point arms just don't want to go down. I appreciate the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 55 minutes ago at 1:05pm
Ive got a 8070 that does the same thing. I take a comealong and hook to the arms and go under the drawbar and pull them down. After they start moving it works fine. Ive sprayed around the rockshaft with penetrant and i think that helps some but it still sticks sometimes
1984 80780
1957 D14
616 tractor
DAC9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAC9 Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 2 minutes ago at 1:58pm
I have the same issue with a D17 Series 4 I purchased. It appeared the lift arms were up, hydraulic cylinders extended, for a long time prior to my ownership. I decided to remove the cylinders and have a local shop ensure they work properly. They had a hard time getting the frozen cylinders to retract. Putting the repaired cylinders back on the tractor helped the issue. The lift arms will go down. Unfortunately, if they are left up long enough (maybe a few months) more than a couple hundred pounds is needed to encourage them to go down. I have also lubricated everything I can see to be a moving part within the linkage, including the plunger under the cap secured by allen screws. I would definitely confirm the cylinders are not frozen in the extended position.
