Ford edge brakes |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1576 |
Topic: Ford edge brakesPosted: 1 hour 11 minutes ago at 3:04am |
Hey guys wondering if you've ever run into something like i did this weekend.
2013 ford edge. Brakes worked great right at first but if you held them say your at a stop sign they would steadily sink to the floor and the brake holding power would go away. Must be a bad master cylinder. Removed it which was a chore on its own. Got new master and bench bleed it with block off plugs where the lines would go. Put it together and absolutely no brakes at all. Dad comes to help and he suggested to bleed the master the old school ways with lines going from the ports back into the resvoir. Put it all together and still nothing. Crack the lines loose at the master and use my power bleeder. Seems good. Went around to each wheel and power bled them. Still nothing. Had dad in the car pumped it up 3 times cracked each master cylinder line. No help. Dad asked about the abs. So we did a power bleed of that using a scan tool. We then finished the night with the pump 3 times hold and I Crack the line. None of this helped. I have no brakes at all. What could I have done wrong. I stared with a vehicle that I would be comfy going 80 in and stopping. I wouldn't have felt comfy depending on then holding after an extended period time of holding the pedal but at least it was drivable. I'm at the point I wouldn't take this over 2 miles per hour. |
