D21 hydraulic ?
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: D21 hydraulic ?
    Posted: Yesterday at 5:59am
What pressure should be at the hookups? Will a D21 struggle to raise modern heavy duty equipment? Spent the day yesterday hooked up to a 18 ft, I dont know what it is really called, renovator, straight disc blades then another row of disc then two rows of spinning leveling drums. At first thought the clutch was slipping thankfully I was spinning out. I ran her for all it could pull for six hours. Had to stop to replace a O ring below the hydraulic pump. But even when I first hooked up, relevilty cool, it fought raising this thing up or folding the wings.
Edited by whatscooking - Yesterday at 6:13am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:27am
Remote outlet pressures are to be 2,200 psi with the engine at full throttle and warm hyd oil. Some have been adjusted upwards to 2,400 psi and that would be the max. Modern implements sometimes require 2,900 psi. Sometimes, not always. Wings to implements are oftimes orificed to actually make them slow, for safety reasons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:32am
There's also a possibility you might have hydraulic coupler mis-match. And also a possibility that your 12 to 14 GPM hydraulic pump doesn't look so good on a modern implement that may have many large diameter hyd cylinders and requires 25 or 50 GPM to make them work at a decent speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:46am
It does have large diameter cylinders and long.
Taking the 7060 today to give it a work out. I'm in a 70 acre field that just got the beans out. Water pump just in, welded and sealed the cab. This tractor hasent seen 180 thermostats for awhile and I'm taking her to a pull.
Edited by whatscooking - Yesterday at 11:48am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:14pm
7060 is a 2500 psi system with 17 GPM out of each remote valve IF THEY ARE SET CORRECTLY with the rabbit/turtle levers under the seat. One speed lever for one remote valve. Three valves and only one rabbit/turtle lever?? you can only adjust ONE valve for speed/flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 23 minutes ago at 5:30am
7060 didnt like lifting it either. Tell me more about mis matched coupler?
I wanted to take advantage of this opportunity to put both the D21 and 7060 through their paces to get some more of the bugs out.
This tool i was pulling was real, Great Plains Turbo Max 1800 TM. The blades were set straight and the debth was at 3.5 max. Covering cover crop seeds on bean ground. The temp guage on the 7060 would creep up to the needle straight up and past which I was able to read with a lazer pointer, was 200 +. I unhooked and went to his shop. I did blow and wash at my house cuase I knew the PO used the tractor for bailing, thought I was good. He had a long air gun bent with rubber tip. I unscrewed the fan shroud so i could get to the 4 corners.I blew with clouds comming out and blew even more and garden hosed and blew again for more than hour. Back to the field. First mark on temp guage is for the 180• thermostats i put in and straight up is 200. It held between the two.
I found the company that makes and sells a flat blow gun, AGCO carries them. I know it needs more cleaning. You could see the gunk pushing out like a zit when I washed and blew.
Overall both tractors passed this test, with a few minor adjustments.
Edited by whatscooking - 11 hours 56 minutes ago at 5:57am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 56 minutes ago at 6:57am
It's pretty easy too come up with the specs of this machine:   `18 feet wide.....takes minimum of 180 HP to pull.......weighs 15,200 lbs (more than a D-21 does)..... and it requires FOUR hydraulic valves......and it requires one of those valves to be turned on constantly to provide down pressure to the wings.  It doesn't tell me how many GPM's are needed but I know the D-21 has no business being hooked to it and I'm questioning if a 23 GPM main pump on a 7060 is even enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 59 minutes ago at 7:54am
5th gear
Edited by whatscooking - 9 hours 50 minutes ago at 8:03am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 55 minutes ago at 7:58am
1st high range
Edited by whatscooking - 9 hours 49 minutes ago at 8:04am
68 D21 81 7060
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 37 minutes ago at 9:16am
  On a side note, duals help greatly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 17 minutes ago at 9:36am
The 7060 has 42 radials with fluid and one wheel weight per side and the D21 has 24.5 x 32 dry no fluid. When I first droped that thing deep in the ground with the 21 I was sure the clutch wasn't holding. Then I saw the dirt blowing back. The 60 ran with it if I ran the machine like he wanted.
I know both tractors would not of been correctly matched especially if you angled the blades and sunk it it but boy did I enjoy those two days. Used 31 gal in the 21 and 39 in the 60.
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 54 minutes ago at 3:59pm
68 D21 81 7060
