‘Nother Water Question |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12513 |
Topic: ‘Nother Water QuestionPosted: 1 hour 60 minutes ago at 7:07pm |
Soooo… it’s recommended that the air pressure in the bladder tank be set 2-3 psi lower than cut on pressure.
Water at dad’s was acting up. Biggest problem turned out to be the sense line to the switch was plugged. Anyway for thoroughness I replaced the pressure switch. Guess I bought a lower pressure setting. I bought a 30-50. When the switch kicks on bladder tank pressure is about 35. It seems to be working fine and cycling normally with a steady flow of water. So, ??? Should I put a 40-60 on it? It doesn’t seem to be broke so I tend to not wanna fix it! Got plenty of other things to do.
