7030 Block Heater |
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 376 |
Topic: 7030 Block HeaterPosted: 05 Oct 2026 at 4:24am |
I decided to put a block heater in my 7030 in case it is needed this winter. It has had a combine engine put in it so it doesn't have one now. I don't know a lot of history on the tractor so I plan to change out the coolant at the same time. The question I thought of is what are the chances of the plug coming out clean after 50 years? And then is there a good way to repair the threads in the aluminum casting? Thanks in advance.
![]() Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Thanks(1)
Posted: 05 Oct 2026 at 7:28am |
If it was mine, I'd have the engine fully warmed up to operating temp and carefully use a 1/2" impact wrench to get it to move and know it is loose. Have your hand on the socket to control what's happening to keep it from completely coming unthreaded !!!
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9229 |
Posted: 1 hour 11 minutes ago at 9:31am |
Heat around plug to grow the AL ?
