Gas tank |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 451 |
Topic: Gas tankPosted: 15 hours 36 minutes ago at 8:53am |
For storage over winter, is it better to have a full tank or empty to minimize rusting?
'41 Allis B
'49 Farmall Cub |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6687 |
Posted: 13 hours 14 minutes ago at 11:15am |
Full, less space for condensation.
Joined: 11 Sep 2009 Location: illinois Points: 93272 |
Posted: 11 hours 37 minutes ago at 12:52pm |
I think it depends on where you live. Hubert has a lot of high humidity in his area.. Where i live the humidity is very low in the winter. I like to keep the tanks as low a possible to keep the posibility of gas going bad.. Normally gas in our area is good for several months ( even the 10% ethanol)... but i run the tanks low, then put a couple gallons back in during april / may and fire them up for the summer.. Never have a carburetor plugging problem. .. also have pretty good luck with no oxidizing of the magneto point... They just fire up after setting 5-6 months..
Got a CASE 530 backhoe with a distributor.. do the same with it.. it can set 6 months at a time, no problems. Edited by steve(ill) - 11 hours 36 minutes ago at 12:53pm |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5015 |
Posted: 9 hours 49 minutes ago at 2:40pm |
Factors other than humidity come into play. I bought an old Cat had been sitting in a barn out in a country that only averages about 8 inches of rain a year. I have relatively low humidity at my place 50 miles west with 20 inches of rain average. So this had to be lower humidity yet. I have never seen rust like this tank had. An L shaped tank and over 2/3 full of old time diesel that burned just fine once filtered from the rust. But a very good example of what happens to tanks not full of fuel.
john2189
Posted: 8 hours 36 minutes ago at 3:53pm |
I live in Ohio long cold winters. My garden tractors have plastic tanks so I am not worried about them.
'41 Allis B
'49 Farmall Cub |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1426 |
Posted: 1 hour 17 minutes ago at 11:12pm |
I seem to leave all my gassers empty and diesels full, last time I left a gasser full (steel tank) over winter the gas ended up with water in it and cracked the sediment bowl also messed the carb up.
