Smallest silo?
500592 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Topic: Smallest silo?
    Posted: 12 hours 46 minutes ago at 5:41pm
What’s the smallest silo someone has ever heard of? I’ve been day dreaming of getting a couple of beef cows. What’s the smallest silo someone has seen? Would it be possible to build an old fashion wood silo say 4’ or even 8’ in diameter and about 16’ tall to feed a bit of chopped grass or corn in the winter months? No much ag around here anymore so it would be hard to buy small amounts of silage for just a couple cows and it would be nice to chop the first crop early when it’s hard to make dry hay. I’ve got a sawmill and well equipped wood shop so making the staves wouldn’t be too hard. Any chance of this working or would it just be a large compost bin?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 1 minutes ago at 7:26pm
I fill a 12 by 40 silo that has a surface drive uploader. I fill it in October and its gone by june. Remember if you fill an upright silo you are going to have a couple of inches of spoilage on the walls. You also need a certain height to create enough force to eliminate any oxygen. I would think a wooden structure may be your best bet. Having said that, you are trying something different make sure you get it tested before you feed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 59 minutes ago at 7:28pm
It can be done, but sealing a wooden silo and keeping it sealed would be the hard part...Wink
I just remembered a story in farm show magazine, the title for the article is "silo trailer attracts attention".  It's about a salesman's model of a Unadilla silo, 10 or 12' tall mounted to a trailer... The story has the guy's name and number or address in it (New York), as most do, in Farm show magazine, and you can search the archives for free, I believe, without being a subscriber...  You may also want to search for Unadilla silo.
The whole trick to efficient silage is to remove enough each day, to keep spoilage to a minimum.  This means knowing how much your hypothetical cows are going to eat, and sizing the silo, both in diameter and in height...  There are formulas for all of this that I can't remember, but was taught back in college, in 1985...Confused
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 23 minutes ago at 8:04pm
Unadilla still exists. They make trusses now, but they did get out the ols tools to build a small silo for Delaware county fairgrounds
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 47 minutes ago at 8:40pm
Ever hear of a silage "bag"  ?? that lays on the ground and gets sealed up when full ??
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 55 minutes ago at 9:32pm
We have a 10x30 cement stave silo still standing. Last time we filled it in the 1980s it only took a short afternoon. I think the other silo grandpa had was a 12x30. That one got replaced by a 16x60. Wood stave silos were in the 10x30 range. They were made from high quality cedar. Some of those board outlasted the actual silos. Just make a ground pile on plastic and pack it and cover with plastic. We have a farmer we open fields for, when I help a silage crew in fall. We dump 2 to 4, 24 ft silage wagons for him depending on what fields he wants opened. That's what he does. Or you can do it between rows of round or big square bales with plastic.
Edited by DanWi - 8 hours 54 minutes ago at 9:33pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 53 minutes ago at 9:34pm
If you are only raising a few head of cattle, I wouldn’t even mess around with silage. Baled hay, and ear corn. Grind your own, is the route I would pursue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 55 minutes ago at 5:32am
Here the typical Is a Silage ‘bag’ or bale wrapped fermenting sleeve of silage they start at one end and feed until is gone. Or as with our Renter a Trench Silo, one aite they use is an old barn footered Concrete Floor fill and mound then cover with old billboard Ad tarps.
Edited by DMiller - 54 minutes ago at 5:33am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 45 minutes ago at 5:42am
An old farmer near me who immigrated to Canada from Holland told me that when they first came out with square balers, farmers in Holland would lay plastic sheets on the ground and stack green (not dry) square bales on the plastic.
When the stack was the size they wanted, they would wrap the plastic around the bales and secure it (maybe use tape?) so no air could get in.
When they needed to feed it, they would then open one of the stacks and feed the ensiled hay out. I suppose they would reclose the unused stack until it was gone.
Edited by WF owner - 44 minutes ago at 5:43am
