Spring a door back
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Spring a door back
    Posted: 12 Aug 2026 at 5:28am
I have done my share of, make her take her, but before I try to get the lower door back in place, not real far out, any tips appreciated.
81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 1:52pm
Patience and gentle correction. Depends on where the sprung area is, go slow, might use shims to push against at proper place.HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 2:27pm
Those doors oftentimes crack just above the door latch area. A horizonal crack that connects to the vertical structure that goes to the front/top of the door frame. I've welded/braced many over the years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 3:15pm
i just worked on a big Case cab that they had the door open and hit a tree while mowing.. Bent the door about 10 inches out... I took the door off and cut the weld and rewelded the area like Dr mentioned.. Thought it was close.... Took the door back and it was about 3 inches off at the top... Mounted the door, put a 2 x 4 between the door and frame at the latch and used a small comealong on the TOP of the door, thru the cab, to the opposite side frame.. winched it a couple times until it fit the latch pretty good.. They actually popped the top window out when it hit the tree..
Edited by steve(ill) - 12 Aug 2026 at 3:16pm
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 3:38pm
I’ve seen a Buddy twist car doors back using a block of wood as a wegde. He told me always try to reverse the twist the way it got twisted. He said he straightens frames the same way. He pulls it out the way it went in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 6:09pm
Sure enough there is a horizontal crack. Expecting alot of that thin metal there. Little piece of angle on the outside?
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 6:15pm
I always tried to peel back the rubber seal and make repairs on the inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 6:32pm
Take out the window?
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 7:05pm
If that's what it takes, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:00am
Thanks
68 D21 81 7060
