D-15 centers |
Kddrck
Joined: 09 May 2021 Location: Paragould, Arka Points: 43 |
Topic: D-15 centersPosted: 11 hours 54 minutes ago at 10:47am |
Friends:
I have a D-15 Series I. I'm in need of two wheel centers for 26" spin out rims. My centers were cracked when I bought the tractor. I had a professional welder weld the cracks. All I do is tractor rides, I don't know why they keep cracking unless they're "bad." Is there anyone in a couple hundred mile radius of Northeast Arkansas that has any? Thanks.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5451 |
Posted: 4 hours 37 minutes ago at 6:04pm |
Your welder is not doing a "proper" job. These centers are hardened somewhat and the area needs to be preheated before welding. Also the rod type or shield gas needs to be used. Did your welder grind out the crack first?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 909 |
Posted: 4 hours 13 minutes ago at 6:28pm |
Ive welded the bar that holdes the teeth on a floating cutter bar. Its tempered. After welding i heated it in a larger area to relieve stresses from welding heat being in a concentrated area. Never broke again. May help may not but its athought
1984 80780
Joined: 11 Sep 2009 Location: illinois Points: 93208 |
Posted: 4 hours 8 minutes ago at 6:33pm |
one good question is WHY did they crack to start with ??
That being said, i have welded plenty of "hard" steel with 7018 stick rod.. Preheat sure dont hurt, especially if the metal is below 50 degrees F to start with... nice to set by the fire or use a torch to get the hub up to maybe 150 degrees before you start..... 7018 does not require pre heat, but you put a lot of stress on a part if its 50 degrees and you do a lot of LOCAL WELDING in one spot on a big part.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11100 |
Posted: 2 hours 57 minutes ago at 7:44pm |
THey crack because of the stress that piercing the square hole causes. The corners are too sharp.
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 644 |
Posted: 2 hours 14 minutes ago at 8:27pm |
I have a series 1 that is being parted out, I'll check centers and see if they are OK or cracked and let you know. I'm in E. Central Indiana
Posted: 2 hours 6 minutes ago at 8:35pm |
how about welding a reinforcing plate behind the square holes... or if not needed, filling them in or rounding them out ??.... still dont see why you would get cracking on a parade tractor..
