D-15 centers
Kddrck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Topic: D-15 centers
    Posted: 8 hours 6 minutes ago at 10:47am
Friends:
I have a D-15 Series I. I'm in need of two wheel centers for 26" spin out rims. My centers were cracked when I bought the tractor. I had a professional welder weld the cracks. All I do is tractor rides, I don't know why they keep cracking unless they're "bad." Is there anyone in a couple hundred mile radius of Northeast Arkansas that has any? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 49 minutes ago at 6:04pm
Your welder is not doing a "proper" job. These centers are hardened somewhat and the area needs to be preheated before welding. Also the rod type or shield gas needs to be used. Did your welder grind out the crack first?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 25 minutes ago at 6:28pm
Ive welded the bar that holdes the teeth on a floating cutter bar. Its tempered. After welding i heated it in a larger area to relieve stresses from welding heat being in a concentrated area. Never broke again. May help may not but its athought
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 minutes ago at 6:33pm
one good question is WHY did they crack to start with ??
That being said, i have welded plenty of "hard" steel with 7018 stick rod.. Preheat sure dont hurt, especially if the metal is below 50 degrees F to start with... nice to set by the fire or use a torch to get the hub up to maybe 150 degrees before you start..... 7018 does not require pre heat, but you put a lot of stress on a part if  its 50 degrees and you do a lot of LOCAL WELDING in one spot on a big part.
