Tillage Question |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12507 |
Topic: Tillage QuestionPosted: Yesterday at 7:05am |
Not color specific.
What tool have you guys had luck with for tall and or thick sod? My big moldboard plow does ok, but there are fields where it’s not too handy. And honestly…..it could be better. Glencoe soil saver is a no-go, it’s plugging. My most recent small plow is an IH 400. That plow does a wonderful job and pulls easily…right up until it doesn’t, then it’s miserable. In heavy sod, it rides up and gets caught on the shank and from there is all downhill. It seems to me the colters are too big and too close to the moldboard, and also not much clearance under the frame. You get to a point where you’re only 3 inches deep, then to a point where it still scoops up grass and it’s all plugged up. Just curious if anyone has good luck in such a case. |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8573 |
Posted: Yesterday at 7:26am |
As for the grass/sod/trash on the surface, try disking the field first. Or, mowing, baling a crop off the land first. As for coulter and plow adjustments, get an owners manual for that specific plow. Does the the plow have ‘coverboards’? Some call them ‘trash boards’. Proper ground speed can also affect the performance of a moldboard plow.
Posted: Yesterday at 7:50am |
I've never done this, or for that matter even seen it done, but in the old days, they would tie a length of #9 wire on a coulter or somewhere on the frame, and that dragging wire would fold over the tall brush so it didn't plug.
Tbone95
Posted: Yesterday at 9:09am |
There are two locations to mount the colters. Already in the farthest forward, won’t even fit in the rearward one. Makes me wonder if it’s the correct colters. I’m doing the mowing and baling. Would sure love to skip that and save the time and fuel. Nothing to do with coverboards, it doesn’t get that far and if it does it turns over fine. |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2763 |
Posted: Yesterday at 9:19am |
My friend used to have a pair of IH #720 plows; 5-16' & 6-16". They would only plug in very heavy (and/or damp) cornstalks. Sod plowing was a breeze. FWIW.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3789 |
Posted: Yesterday at 10:44am |
The later years AC 2000 plows had 32” of clearance. And if it was setup with high speed 392 moldboards, then even better.
Tbone95
Posted: Yesterday at 11:49am |
Tbone95
Posted: Yesterday at 11:51am |
I used to have one, it pulled great, and as I recall I turned over a lot of sod with it. I remember it doing very well. We had trouble sourcing wear parts for it is why we parked it. Since sold it. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5446 |
Posted: Yesterday at 12:42pm |
I've seen a properly set plow go through weeds taller than the top of a tractors muffler without plugging. Coulters + jointers and weed hooks
Find a set of concave coulters for your plow, anyone can make any plow go through anything without plugging with them.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9219 |
Posted: Yesterday at 3:43pm |
Dad had a#9 wire tied on the 2 bottom 52. Just the front bottom but it also had them coulters which had a small concave coulter paired with it. Can't remember the brand name.
Tbone95
Posted: 18 hours 11 minutes ago at 1:47am |
How/ where is this wire tied?
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3178 |
Posted: 12 hours 44 minutes ago at 7:14am |
Lance coulters?
Posted: 12 hours 41 minutes ago at 7:17am |
I think it gets tied to the rolling coulter shank and is routed to the inside of the coulter blade so it gets drug towards the moldboard. It folds over the brush pretty flat so it doesn't plug the throat between the bottoms. It would extend at least as long as the moldboard and maybe a little beyond. Say what you want, but I'm sure this was a well-known trick 60 and 70 years ago with 12 and 14 inch plow bottoms and not much throat opening on ANY plow of that day.
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 643 |
Posted: 12 hours 19 minutes ago at 7:39am |
Yes for the #9 wire solution! As a kid, I remember Dad using this for sod, cornstalks, or whatever needed. Also, yes for anchoring wire to Coulter standard and letting it trail past end of moldboard. Good luck!
Tbone95
Posted: 11 hours 53 minutes ago at 8:05am |
Interesting. Still not sure I’m visualizing correctly. A loop, or just a straight wire dragging? Only tied on one end? If I get a chance in the next couple days I’ll put one on and take a picture and see if I’m on the right track. Thanks for the discussion guys.
Joined: 11 Sep 2009 Location: illinois Points: 93195 |
Posted: 10 hours 26 minutes ago at 9:32am |
yes, i would like to see a picture or a drawing of that... I dont understand what dragging a wire does ???
Tbone95
Posted: 10 hours 8 minutes ago at 9:50am |
I’ve been thinking heavily, smoke starting to roll out of my ears. The visual I’m getting is if you picture direction of travel, tie the wire to the colter shank and rout it to the left of the colter. Then bend it about 90 degrees or maybe a little less and route in front of the moldboard, the whole width of the moldboard. That way you would be folding over the grass in front of the moldboard as you travel. I think. Hard to imagine it’s stiff enough but must work since several have mentioned it. Edited by Tbone95 - 10 hours 7 minutes ago at 9:51am |
Posted: 8 hours 34 minutes ago at 11:24am |
As i remember the wire was as long as tip of mold board and bent to follow contour of mold board. It just flopped loose. The dirt being turned kinda buried the trailing end which held it in place to force grass etc to lay down and get covered. The wire was not tightly tied around coulter shank. Just looped. and tied back on itself. That was 50 yrs ago so may not be 100% correct.
Posted: 8 hours 13 minutes ago at 11:45am |
Secured at the coulter shank end, yes. But make sure you get it wrapped so it doesn't pull apart as there will be a pretty good tug on that wire tucking and bending over the tall stuff.
Tbone95
Posted: 7 hours 22 minutes ago at 12:36pm |
Well, with any luck and a spare half day, I’ve got an acre spot in a field that I’ve had to stay out of the last two years because it’s wet, I will be giving it a try.
Thanks again. |
Posted: 6 hours 47 minutes ago at 1:11pm |
I didn't clarify... a single strand of #9 wire is being drug along.
Mo farmer
Posted: 6 hours 10 minutes ago at 1:48pm |
https://talk.newagtalk.com/forums/thread-view.asp?tid=543996&DisplayType=flat
Look at this. This is the way grandpa would rig #9 wire to cover tall grass. |
Tbone95
Posted: 5 hours 60 minutes ago at 1:58pm |
Hey mofarmer, thanks! I get it. I was over complicating things in my head.
Posted: 5 hours 52 minutes ago at 2:06pm |
well dragging it down the bottom of the furrow and burying it on the back makes sense now,... I pictured it running side to side and didnt see how that was going to do anything !!
Posted: 5 hours 20 minutes ago at 2:38pm |
As low as possible on the front looks best to me.
