Tillage Question
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Tillage Question
    Posted: 5 hours 38 minutes ago at 7:05am
Not color specific.
What tool have you guys had luck with for tall and or thick sod?
My big moldboard plow does ok, but there are fields where it’s not too handy. And honestly…..it could be better.
Glencoe soil saver is a no-go, it’s plugging.
My most recent small plow is an IH 400. That plow does a wonderful job and pulls easily…right up until it doesn’t, then it’s miserable. In heavy sod, it rides up and gets caught on the shank and from there is all downhill. It seems to me the colters are too big and too close to the moldboard, and also not much clearance under the frame. You get to a point where you’re only 3 inches deep, then to a point where it still scoops up grass and it’s all plugged up.
Just curious if anyone has good luck in such a case.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 17 minutes ago at 7:26am
As for the grass/sod/trash on the surface, try disking the field first. Or, mowing, baling a crop off the land first. As for coulter and plow adjustments, get an owners manual for that specific plow. Does the the plow have ‘coverboards’? Some call them ‘trash boards’. Proper ground speed can also affect the performance of a moldboard plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 53 minutes ago at 7:50am
I've never done this, or for that matter even seen it done, but in the old days, they would tie a length of #9 wire on a coulter or somewhere on the frame, and that dragging wire would fold over the tall brush so it didn't plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 34 minutes ago at 9:09am
There are two locations to mount the colters. Already in the farthest forward, won’t even fit in the rearward one. Makes me wonder if it’s the correct colters.
I’m doing the mowing and baling. Would sure love to skip that and save the time and fuel.
Nothing to do with coverboards, it doesn’t get that far and if it does it turns over fine.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 24 minutes ago at 9:19am
My friend used to have a pair of IH #720 plows; 5-16' & 6-16".  They would only plug in very heavy (and/or damp) cornstalks.  Sod plowing was a breeze.  FWIW.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 59 minutes ago at 10:44am
The later years AC 2000 plows had 32” of clearance. And if it was setup with high speed 392 moldboards, then even better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 11:49am
I am so glad you made this comment! That is very specifically one of the things I wondered. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 52 minutes ago at 11:51am
I used to have one, it pulled great, and as I recall I turned over a lot of sod with it. I remember it doing very well. We had trouble sourcing wear parts for it is why we parked it. Since sold it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 58 seconds ago at 12:42pm
I've seen a properly set plow go through weeds taller than the top of a tractors muffler without plugging. Coulters + jointers and weed hooks
  Find a set of concave coulters for your plow, anyone can make any plow go through anything without plugging with them.
