D17 Diesel Ignition Switch
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Topic: D17 Diesel Ignition Switch
    Posted: 22 Sep 2026 at 10:57pm
Does anyone have a pin out for the D17 Diesel ignition key switch?
I'm wondering if it has a position for the glow in the intake etc. Right now it has no stops, it just turns til the start position and then back, there's a voltage leak, so I leave the battery disconnected.
1957 D17 Diesel w/ M&W Pistons
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:23am
Coke, my old service manual shows the D15 Series II having the heater solenoid wire built into the key switch.... the OLDER D15- 17 wire diagram shows the switch giving power to a HEATER BUTTON , which you then have to manually PUSH to energize the heater.... so the question is, do you have a BUTTON ?? .. and is your D17 a series 1 or 2.. or possibly the series 4 had the key like the D15 Series 2 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:27am
this shows the earlier models with  the BUTTON..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 32 minutes ago at 8:27pm
Funny how they did things. My 220 has a push button for starter and you twist key to right to energize heater
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 11 minutes ago at 11:48pm
Coke
I purchased a D17 III Diesel a few years ago and it had the ignition switch set up to have the push button energize the manifold heater, with the key in the on position. Ignition key to full clockwise would crank the engine
I changed the wiring to be the same as my factory 185, key to on position - push button will crank the engine, key full clockwise will energize the manifold heater.
Personal preference, either setup got the job done
The D17 IV and 185 operating manuals suggest keeping the manifold heater energized when cranking the engine over, in colder starting conditions to improve starting the engine
I have not used this procedure.  I plug in the block heater on either tractor and use the manifold heater for about a minute and that is enough for starting
Perhaps if one decided to keep the manifold heater energized when cranking the engine one of these configurations would be easier to execute????????
The safety switch / push button to energize a motor is a standard industrial design feature.  I feel it is a very safe way to start the tractor
Hope this info helps you with your D17 Diesel
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 34 minutes ago at 6:25pm
Mines from 1957, not sure what that makes it.
You can see where I removed the key switch, and the black dome is the switch I am fitting just for the starter, other than that there's just a light switch?
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 27 minutes ago at 6:32pm
What sort of block heater are you using? The dipstick type seemed easy to me, haven't got one yet.
