Nylon Bushings
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: Nylon Bushings
    Posted: 16 Sep 2026 at 7:08am
Does anyone know a good source of nylon bushings or bushings made from a similar material? Specifically I need a bushing with a 1 1/4 inch outside diameter and a 7/8 inside diameter.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2026 at 7:24am
McMaster-Carr has several types in that size
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2026 at 3:27pm
If you have a wood lathe, you can turn them from just about any nylon stock.  I needed some bearings for the castor wheel on the front of my zero-turn mower, had some 1 X 6 black nylon boards I picked up from craig's list real cheap, so as a temporary measure, I turned some 1/2" ID X 1-1/2 OD bushings with a skew chisel, real quick on a Sunday mornin, and them things are still on the mower.  Once the nylon gets loose and sloppy I'll put the right parts into it, but I'm cheap, and can wait...Wink
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 11:13pm
I got tired of looking for just the right plastic bushings, and making bushings from plastic on my lathe... I bought a 3D printer, loaded it with PET-G filament, and never looked back...
1 1/4 inch outside diameter and a 7/8 inside diameter...  HOW LONG?
I can draw that bushing in 4 minutes, and print it in probably 10.  PM me your address, and tell me length, and how many you need!
DK  :-)
Edited by DaveKamp - 17 Sep 2026 at 11:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2026 at 12:00am
Correction... I drew it in 3... and going full solid (100% infill) it takes 18 minutes, plus the 4 minutes it does for self-test/calibration before a run...  this one is only an inch long, but it's running now.
I drew these to exact dimension... the printer nozzle is usually pretty accurate, but when going full-solid sometimes the IDs are a smidgen tight, and the ODs are a smidgen fat... so if either are really critical (meaning, it won't work with any variation), then either it gets hand-dressed to size (sandpaper on a dowel) or I make a little adjustment to the drawing to compensate, and re-run it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2026 at 12:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2026 at 12:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 10:04pm
Gary- check your PMs... should be in your mailbox around Saturday or so.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2026 at 10:19pm
thats very cool
