WD45 Radiator |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3270 |
Topic: WD45 RadiatorPosted: 19 Sep 2026 at 5:55am |
Looks like my 1955 WD45 is going to need a new radiator.I see there are several different choices in a wide price range.What would be a good choice?
Phil48ACWC
Posted: 19 Sep 2026 at 6:06am |
https://www.ebay.com/sch/i.html?_nkw=Radiator+for+Allis+Chalmers+WD+45&_sacat=0&_from=R40&_trksid=p4624852.m570.l1313
Click on above: I installed one of these aluminum radiators in my WC. Love it, no regrets. I did make some modifications to the radiator mounting. I did not bolt the radiator to the radiator shell and the engine cover. I threaded 2 short studs in the bottom radiator mounts just to keep the radiator properly located. I put 3/8" thick rubber pads between the radiator and the frame of my WC. I used springs to hold the radiator down against the frame instead of bolting it down with 1/2" bolts as was done originally. The top of the radiator is held in place with the upper hose cut to an accurate length. All this was done to isolate damaging vibration from the radiator. My brand new original style brass/copper radiator was mounted as originally intended by AC which cracked and started leaking 4 times over 15 years of use. I had a local reputable radiator shop fix the radiator twice and I fixed it twice. I got real sick of repairing that thing. The first sign of problems was the 4 triangular panels that act as a fan shroud, would crack at the solder connections between the panels and the engine side of the radiator. My present well built Aluminum Radiator with vibration isolation as described above has been in use now for 3 years with no issues so far. I'm convinced the original rigid mounting was the culprit. I gave the brass/copper unit away to a guy with another WC. He said he could fix it. I said "Good Luck". I was glad to get rid of it.
Edited by Phil48ACWC - Yesterday at 6:52am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5438 |
Posted: 19 Sep 2026 at 7:10am |
I've had very good luck with the ones that Shoop sells. The ones I've gotten from them for the little Allis Chalmers tractors have all been made in Ireland. Most likely from the same company that was making them for Allis Chalmers UK.
I did once get one of the Aluminum B,C, CA radiators and the grill shroud would not fit over the radiator. This was a nice look well built radiator, just did NOT fit properly.
Edited by PaulB - 5 hours 8 minutes ago at 8:55am |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7716 |
Posted: 19 Sep 2026 at 8:23pm |
Get your old one recored. Will be as good as new. If it does have any problems, the shop that did it will stand behind their work. What happens if you have a problem with one you bought on e-bay???
Gary Burnett
Posted: Yesterday at 8:15am |
This radiator has had several repairs over time apparently including to the upper tank so I can't see sinking money into it.Also in my area I have no idea if anyone recores radfiators any more.
DSeries4
Posted: Yesterday at 8:57am |
Google radiator repair in your area. Only the the tanks and frame get reused. Everything else gets replaced. A good shop can fix the tanks too |
Ricky38
Posted: Yesterday at 11:58am |
A lot of guys have great luck with Shoop's radiators; they're well-made and fit right. If you want to save some cash, the cheaper aluminum ones on eBay work, but they often need a little creative mounting to isolate vibration and prevent cracking. Just make sure whatever you get has the built-in overflow pipe running down the side, or your grill shell won't fit back on properly.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3171 |
Posted: 8 hours 36 minutes ago at 5:27am |
Make sure your new one has the overflow tube built in. Mini didn't. It just has the little pipe sticking out of the neck to attach a hose to. I had to notch my shet metal to get it to fit.
Phil48ACWC
Posted: 6 hours 60 minutes ago at 7:03am |
Recore for my WC around here is about $400. I bought a new Aluminum Radiator for half that. I recently had the radiator recored for my Case 580 Back Hoe for $600. I also could have bought a new aluminum radiator for half that. Simple math. Two recored radiators for $1000 or two new radiators for $500.
Edited by Phil48ACWC - 6 hours 56 minutes ago at 7:07am |
Posted: 5 hours 43 minutes ago at 8:20am |
There have been some pretty poor aluminum radiators that have been marketed as "will fit" a certain model tractor and then they really don't fit nicely or maybe not at all. For those that have had a good experience, good for them. But, I have read about several bad experiences that the aluminum radiator just wasn't made correctly. It's not because they were made of aluminum. It's because they were fabricated poorly. I have no idea how many brands there are or who sells them, but just beware there are poor quality repair parts out there these days.
Edited by DrAllis - 5 hours 43 minutes ago at 8:20am |
