WD45 Radiator
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Radiator
    Posted: Yesterday at 5:55am
Looks like my 1955  WD45 is going to need a new radiator.I see  there are several different choices in a wide price range.What would be a good choice?
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:06am
https://www.ebay.com/sch/i.html?_nkw=Radiator+for+Allis+Chalmers+WD+45&_sacat=0&_from=R40&_trksid=p4624852.m570.l1313
Click on above:  I installed one of these aluminum radiators in my WC. Love it, no regrets. I did make some modifications to the radiator mounting. I did not bolt the radiator to the radiator shell and the engine cover. I threaded 2 short studs in the bottom radiator mounts just to keep the radiator properly located. I put 3/8" thick rubber pads between the radiator and the frame of my WC. I used springs to hold the radiator down against the frame instead of bolting it down with 1/2" bolts as was done originally. The top of the radiator is held in place with the upper hose cut to an accurate length. All this was done to isolate damaging vibration from the radiator. My brand new original style brass/copper radiator was mounted as originally intended by AC which cracked and started leaking 4 times over 15 years of use. I had a local reputable radiator shop fix the radiator twice and I fixed it twice. I got real sick of repairing that thing. The first sign of problems was the 4 triangular panels that act as a fan shroud, would crack at the solder connections between the panels and the engine side of the radiator. My present well built Aluminum Radiator with vibration isolation as described above has been in use now for 3 years with no issues so far. I'm convinced the original rigid mounting was the culprit. I gave the brass/copper unit away to a guy with another WC. He said he could fix it. I said "Good Luck". I was glad to get rid of it.
Edited by Phil48ACWC - 4 hours 1 minutes ago at 6:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:10am
I've had very good luck with the ones that Shoop sells. The ones I've gotten from them for the little Allis Chalmers tractors have all been made in Ireland. Most likely from the same company that was making them for Allis Chalmers UK.
   I did once get one of the Aluminum B,C, CA radiators and the grill shroud would not fit over the radiator.
Edited by PaulB - Yesterday at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 30 minutes ago at 8:23pm
Get your old one recored.  Will be as good as new.  If it does have any problems, the shop that did it will stand behind their work.  What happens if you have a problem with one you bought on e-bay???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 38 minutes ago at 8:15am
This radiator has had several repairs over time apparently including to the upper tank so I can't see sinking money into it.Also in my area I have no idea if anyone recores radfiators any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 56 minutes ago at 8:57am
Google radiator repair in your area.  Only the the tanks and frame get reused.  Everything else gets replaced.  A good shop can fix the tanks too
