AC 7000 series Cab;
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Topic: AC 7000 series Cab;
    Posted: 26 Aug 2026 at 4:33am
Are the rubber isolators for mounting these cabs still available.?
 Looking at a 7045 that will need all new for the rear, so would like to do front and rear if still available.
 It's low hours on engine rebuild and this spring it had hydraulic and transmission work done at local AGCO Dlr.
 I know that AGCO no longer has them for the 200 tractors, but no idea on 7000 or 8000.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 4:43am
AGCO Part # 70577257 Rear And 70266515 Front
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 7:53pm
Thank you for the reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 9:39pm
Whenever I did one of those jobs, I placed four isolators across the front channel (only three from Milwaukee) and two more at the rear channel (where there are currently none). The rear two I don't even bolt in place. Just fit them in the holes provided and they will sit there and not escape. The cab will feel different than it ever has with six small isolators under your feet.
This page was generated in 0.075 seconds.
