6080 Alternator Pulley |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 110 |
Topic: 6080 Alternator PulleyPosted: 23 Aug 2026 at 2:22pm |
Is there a replacement for the alternator pulley out there somewhere? The pulley on my 6080 is wore out to the point where its eating belts and is an issue. Agco and Hy Capacity don't have one available, and ive tried a couple aftermarket that are the wrong bore size or too thick overall. I don't have a good machine shop locally so trying to avoid that route if I can. The pulley that I have is 3.5" O.D., .670" I.D., and is a double v for 1/2" belt.
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5435 |
Posted: 23 Aug 2026 at 2:54pm |
www.brillman.com has a double pulley for 1/2" belts that is 3-3/16 for a 17MM Shaft. part # B9028-015
KJCHRIS
Posted: 23 Aug 2026 at 8:03pm |
I'd try searching these 2 numbers online: 778-1062 and AGCO 70262155.
#778-1062 pulley is replacement for; AGCO #70262155. a 2 groove, 1/2" belts, 3 1/2" OD, .670" bore, the catalog didn't list pulley outset dimension. Fits 6060, 6070, 6080, 7010, 7020, 8010.
Sadly, company that had these closed a year ago. |
Joined: 11 Sep 2009 Location: illinois Points: 93066 |
Posted: 23 Aug 2026 at 8:23pm |
https://www.hy-capacity.com/electrical/components/pid6322/alternator-pulley/
when you click on the link it puts a "/%20" on the end of the link... backspace and delete those 3 symbols. Edited by steve(ill) - 23 Aug 2026 at 8:26pm |
JoeOnt
Posted: 27 Aug 2026 at 5:23pm |
Doing some quick searching, the closest thing I can find A&I A-AFD5012. Shows a little small, but depending on how they achieve it being rated for a 10 & 13mm belt, the 13 (1/2") belt may ride out some, which would help the practical diameter some.
Mikez
Posted: 28 Aug 2026 at 8:22am |
We are also having belt issues.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2548 |
Posted: 29 Aug 2026 at 5:41pm |
The parts house that I get most of me electrical stuff lists a pulley for 6060,6070,6080,7010,7020,and 8010. Replacing #70262155. 3 1/2" outer diameter,.670 bore,1/2 inch belts. They have good stuff and cheap.
