Bad ammeter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Bad ammeter?
    Posted: 10 Aug 2026 at 1:59pm
Put a new wiring harness and gauges in my D15 diesel.  Everything seems to be hooked up properly.  However, the ammeter does not like to move.  Does not move (charge or discharge) when I turn on the lights and/or trigger the manifold heater.  The only time it did move was when I flashed the generator - went over to charge and then returned to zero.
Have not had the engine running yet.  I want to get any gremlins behind the dash sorted out before putting the fuel tank back on.
If it's not the ammeter, what else could it be?  I do have 12+ volts on both terminals of the gauge.
Appreciate any assistance!
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 3:27pm
The wiring diagram I have for the gasoline D15 shows that the ammeter is not in the circuit for the lights, and I suspect that the diesel pre-heater is also not connected through the ammeter.
Since you did get meter movement previously then the meter is probably good.
Edit: The lighting circuit is connected to the "L" terminal on the voltage regulator, you could probably use an ohmmeter to verify if the manifold heater is also connected there, which I suspect it is.
Edited by Les Kerf - 10 Aug 2026 at 3:33pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 3:54pm
there is a HOT WIRE on the starter that feeds the amp meter... where does the wire on the OTHER SIDE of the amp meter go ???? If you have an "L" terminal, that explains it... If it runs to a common FEED TERMINAL for the tractor, thats another problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 3:16pm
The original wiring harness only had one wire going to the voltage regulator - the one for BAT.  The L terminal was not used.  I don't have the wiring diagram from the manual with me now, but I was pretty sure I had wired it correctly.  Can't remember where the ammeter connections go at the moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 3:34pm
Is this a ready-made wiring harness that you purchased? I am working under the assumption that you installed a new harness that duplicates the factory connections, if so, the ammeter will not register current draw from the lights according to the only diagram I have.
Edited by Les Kerf - 11 Aug 2026 at 3:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 4:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 5:32pm
i thought the point of the "L" terminal on the regulator was to OPEN when the tractor is RUNNING.. and the "L" gets is power from the Generator... When the tractor is OFF, the contact is CLOSED and the "L" should get power from the "B" or battery... So when not running, your LIGHTS should show on the amp meter.... Your missing a wire or two..
What does power the light switch ???.. wire #7 above...
Edited by steve(ill) - 11 Aug 2026 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 5:38pm
the HEATER needs the starter switch on to get power to the SOLENOID, which then gets BATTERY power to the heater... not thru the amp meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 6:35pm
Thank you for that clarification Steve Smile
That is the problem with this type of inferior wiring diagram, they are incomplete. A proper schematic will show the internal connections of the regulator, from which a proper diagnosis can be made.
This page was generated in 0.071 seconds.
