AC5015 not charging
Chester330 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chester330 Quote  Post ReplyReply Direct Link To This Post Topic: AC5015 not charging
    Posted: 21 Oct 2025 at 6:01pm
what is the  best way to test the alternator and regulator on AC5015
I checked the voltage today running at fast idle was only  at 12.73 volts at the battery
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 8:15pm
i think the 5015 has an alternator with an internal voltage regulator.. Not sure there are parts available for rebuild... Might be cheaper to just install a new aftermarket alternator like a DENSO Mini, etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2025 at 7:19pm
Take it off and bring it to a local rebuilder to run and load test it. He'll be able to tell you how good it is or how bad.  They can be rebuilt, but sometimes it's better to price out a new unit first as Steve mentioned. The little pint size Denso fits a lot of applications with little mods.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chester330 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2025 at 2:42pm
Alternator is putting out 20 volts ac
I just replaced the voltage regulator still nothing
Any help will be c appreciated
T GG anks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 8:39am
you have an EXTERNAL Voltage regulator ??    If the Alternator is puting out voltage , and there is no charge to the Battery. then you have to have a bad regulator or wire harness ???
where did you get a new regulator ?
Edited by steve(ill) - 25 Oct 2025 at 8:40am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2025 at 1:55pm
Wires not conected to amp gauge
Tommy2x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tommy2x Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2025 at 11:24am
There are 2 wire connectors next to where the tach cable is connected to the engine. I found one of the 2 were disconnected. I get about 13.4 volts to the battery on mine when running.
This page was generated in 0.201 seconds.
