Lift cylinder for d10
Hglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hglover Quote  Post ReplyReply Direct Link To This Post Topic: Lift cylinder for d10
    Posted: 04 Jun 2024 at 12:41am
Looking for lift cylinder for d10
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 10:35am
There are 2 different sizes of D10 lift cylinders depending on hydraulic pump is on the tractor.  The tractors with the CA style pump on the side of the PTO unit (Series I) used the same cylinder as a CA does. Then there was an engine mounted pump which uses a larger bore cylinder same as the High mounted PTO pump that the Series II & III tractors had.
  What series D10 tractor are you wanting the cylinder for?  You may get a better response posting in the Classified section.
