D15 oil change
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: D15 oil change
    Posted: 09 May 2024 at 4:05pm
When changing the engine oil on a series 2 after draining the crank case and pulling the oil filter should the oil filter housing drain down after sitting for a few minutes or should it remain full ? Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 5:03pm
Got it figured out.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 9:06pm
So did it drain out from the filter housing?
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 7:03am
No,my guess is the oil left behind is what primes the pump?
