anyboy know the conrod
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: anyboy know the conrod
    Posted: 08 Mar 2023 at 11:21pm
crank and wrist pin diameter, and distance center to center, as well as the distance of pin in piston from the top for a 226ci d17 engine? or know where I can find such information?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2023 at 8:54am
Piston pin diameter .990"  ....     Con rod C to C  is 7 3/8"  I think. Crank rod journal is 2.375" std diameter.     Distance from center of any main bearing to the block deck is 12.656". So if I'm correct on the rod length (might be 7.500")  1/2 of 4.500" stroke is 2.25" plus 7.375" equals 9.625" subtract from 12.656" is 3.031" to the center of the pin at TDC.  Got to check on rod length because I've got two numbers in my head. Maybe the G-226 is 7.500" and the G-262 family is the 7.375".
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 5:21pm
Conn rod center-to-center is 7.500".  So, 1/2 of a 4.500" stroke is 2.250" plus 7.500" equals 9.750".    12.656" minus 9.750" equals 2.906" to the center of the piston pin at TDC.  The crankshaft main bearing centerline to the deck is a number A-C never provided, ( 12.656")  but I got it years ago from my local machine shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2023 at 11:47pm
Thank you sir, much appreciated!
Wait for the Lord;
