18.4 x34 tires
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 18.4 x34 tires
    Posted: 20 Feb 2023 at 2:46pm
i can get 6 of these firestone 18.4x34 they are wore out for farming with the guy is getting four new ones so i can get the old ones for free two of them are in snap coupler rims  ,  two of them look like they are cut , just wore that way.   to much  for a wd ,wc, ?.  how much power to pull with them ?   bear with guys just scronging parts and gathering info for the budgit build
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2023 at 6:46pm
40 years ago, I ran 18.4 x 38's on a 5500 lbs D-17 with 85 PTO HP at 2,000 RPM. Always ran high side of LOW (direct) gear. You don't say what weight or how much HP you've got. Between a WC or WD and late WD/WD45's, the 45 has the slowest gear ratio in LOW gear. A WD45 diesel chassis is 15% slower yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2023 at 8:09pm
still a lot of unknowns in my camp yet lets say wd 3500 lb.  doable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2023 at 9:20pm
My WD in 3500 got 240 lbs of weights (and battery) on the nose with a 200 lb driver and 15.5 x 38 rubber. With 18.4 x 34;s you'll have balance problems on good tracks I think and need 80+ HP to run low gear. with 20 inch drawbar.
Edited by DrAllis - 20 Feb 2023 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 7:14pm
a little update today scored a freebe series 1 d17 gas.    bad news cant go get it until 2 feet of snow melts and it has been sitting out for twenty years with a rod hanging out the bottom of the pan.   what does it take besides cubic dollars to make 85 hp out a 226 ?         i have been  trying  find out what weight most of the other guys in this group here is so i can put somthing together that has the most enteries,  wouldnt be very fun to be the only one in a class
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:48pm
I used 4 1/8" bore M & W pistons (SP-46) from a WC/WD with the 4 1/2" stroke D-17 stock crankshaft yields 240 psi compression 110 octane racing gas minimum. Each piston top was milled off .170" so the pistons didn't hit the cylinder head. Stock head gasket. 175 grind camshaft. D-19 carb with slight main jet drill out. Intake manifold throat opened up as much as possible with a die grinder. All intake valve guides shortened up on the bottom. Ignition timing at probably 20 to no more than 22 degrees BTDC. Gleaner E governor weights. Cannot buy M & W pistons anymore, but new 4 1/8 sleeves are available. I imagine flat top Chevy pistons that fit a .990" piston pin are a dime-a-dozen to work in that size of sleeve. Used M & W  SP-46 parts not advised because there will be a ring edge on the sleeve and the piston now goes up higher than that. It was a very nice cheap engine build. Also takes a 170/175 clutch disc 4-button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 10:47am
thats a lot better than having to go have a stroked crank done . that kind of stuff can come later.       cant seem to find a wd45 crank locally, been watching for one and a tall head to build a spare or change on one of our farm tractors.    i have a half dozen wd engines,  any differance in the wd45 crank and d17 crank
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 11:34am
Those cranks and blocks do NOT interchange !! The D-17 (G-226) has 3 inch main bearings. The WD-45 (W-226) has 2 1/2" mains. Stroke is the same, but cranks do not swap without the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 8:28am
good to know, now i know alittle bit more on what i am looking for
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2023 at 8:49pm
what is the square inches of the 18.4 x 34 tire ?     its not lised in the little chart i found
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 12:56pm
18.4 x 34 foot print is 265 square inches.........18.4 x 38's are 270 sq in........18.4 x 30's are 260 sq inches.....18.4 x 28's are 250 sq in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 7:25pm
that means i realy cant use them for about any pull ,       may have a line on some 38 or 36 galixys  but no rims  thay are wore so sharp they look like they were cut i will see what size they we changed them on aguys tractor a year ago they were on a 4430 jd tomorrow i will go up the road and see what they are
