WD wheel setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: WD wheel setup
    Posted: 05 Oct 2022 at 4:43pm
Pulling my ole WD this weekend for fun at a local pull. New to pulling the WD so I am curious if the wheels should be spun in tight or out? Is there an advantage?
Thanks
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2022 at 5:16pm
As a general rule of what works the best, narrow is best. Why?? because when the wheel tread is wide and one tire gets a greater bite than the other (which happens) it will steer you where you may not want to go and you can't hold it back.
This page was generated in 0.107 seconds.
