Cast versus press steel
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Topic: Cast versus press steel
    Posted: 12 Jul 2021 at 7:25pm
Just wondering if anyone would know how much weight I would loose on my 200 if I took off the 38” cast centers and put on 9 bolt hubs and pressed steel rims , thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2021 at 10:54pm
38 inch power shift wheels weigh more than basic std type 38 inch wheels. Probably lose 500 lbs total but sometimes there's a difference in tire weight too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2021 at 6:07pm
Depends on the 9 bolt adapters/ hubs you put on too - have one set that prolly weighs 300 lbs a set - then another that is around 150 lbs, its the best place to lose weight tho
This page was generated in 0.099 seconds.
