7000 Series Wheel Weights |
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 968 |
Topic: 7000 Series Wheel WeightsPosted: 30 Jan 2021 at 12:57pm |
I have been offered these for me to purchase. Neither seller nor myself know the value. He just doesn't need them anymore. Can anyone give me a range of value? Anyone seen any of these sell? I believe there is a piece on the inside as well. Not sure what the total weight is either. Thanks for the help in advance. ![]() |
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 801 |
Posted: 30 Jan 2021 at 4:34pm |
my guess would be 300 for the pair?
calico190xt68
Posted: 30 Jan 2021 at 5:40pm |
Thanks for feedback. If each side weighs about 300 lbs then that would be closer to 50 cents a lb. That's just a guess on what they weigh. I would be willing to buy at $300. At $600, I don't think so.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4593 |
Posted: 31 Jan 2021 at 11:19am |
FYI These are not A-C weights. Aftermarket
calico190xt68
Posted: 31 Jan 2021 at 2:37pm |
Thanks for letting me know. I wasn't sure if they were a/c part or not.
I am adding weight to tractor for chisel plowing a couple of hay fields, then using unverfurth cultivator to level it. I know I need the front weights but not sure these weights are really needed. So I may not make an offer. |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3807 |
Posted: 31 Jan 2021 at 2:53pm |
Those say “Martinsville” in their casting. So, yes they are aftermarket items. Probably 300lbs each, so $.50 - $.75/lb?
If your tractor has no rear tire fluid, then those exterior weights are somewhat easy on - easy off, as long as you have a loader, forklift, or overhead shop lift available to assist. Inner weights involve removing wheel centers from axles. |
calico190xt68
Posted: 31 Jan 2021 at 3:34pm |
Not sure the guy knows that wheel hub has to come off for inner weights. That might not be worth it. I don't have rear tire fluid.
