Ford edge brakes |
| Author | ||
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1579 |
Topic: Ford edge brakesPosted: 12 Oct 2026 at 3:04am |
Hey guys wondering if you've ever run into something like i did this weekend.
2013 ford edge. Brakes worked great right at first but if you held them say your at a stop sign they would steadily sink to the floor and the brake holding power would go away. Must be a bad master cylinder. Removed it which was a chore on its own. Got new master and bench bleed it with block off plugs where the lines would go. Put it together and absolutely no brakes at all. Dad comes to help and he suggested to bleed the master the old school ways with lines going from the ports back into the resvoir. Put it all together and still nothing. Crack the lines loose at the master and use my power bleeder. Seems good. Went around to each wheel and power bled them. Still nothing. Had dad in the car pumped it up 3 times cracked each master cylinder line. No help. Dad asked about the abs. So we did a power bleed of that using a scan tool. We then finished the night with the pump 3 times hold and I Crack the line. None of this helped. I have no brakes at all. What could I have done wrong. I stared with a vehicle that I would be comfy going 80 in and stopping. I wouldn't have felt comfy depending on then holding after an extended period time of holding the pedal but at least it was drivable. I'm at the point I wouldn't take this over 2 miles per hour. |
| Sponsored Links | ||
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 512 |
Posted: 12 Oct 2026 at 5:26am |
Vacuum brake booster or hose bad?
Edited by john2189 - 12 Oct 2026 at 5:27am |
'41 Allis B
'49 Farmall Cub |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25521 |
Posted: 12 Oct 2026 at 6:19am |
hmm, if you can pump the brake pedal 3-4 times , pedals high, hold, then slowly goes down tot he floor, I'd say BAD rubbers in the master cylinder. It's feeding back ,around the 'loose' rubber from the outgoing side back into the reservoir side. I had that happen on my '57 Willys. pro brake shop ( #1 in Hamilton ) rebuilt the master cylinder, dang near killed me going down a steep hill.... anyway went to local parts store bought a NEW unit with 1/4" of dust on it.... worked 100%. hint.... if you have ZERO leaks..the oil HAS to be going 'somewhere'..round and round the rubber , is my best guess. |
bobkyllo
Posted: 12 Oct 2026 at 8:07am |
Ì also thought the new master cylinder was bad. So i went and got another one with no luck
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12524 |
Posted: 12 Oct 2026 at 8:19am |
This is crazy. I’m not any help at all but following. Because all I can think is that it’s gotta be something really stupid! Please keep us posted!!!
Joined: 11 Sep 2009 Location: illinois Points: 93506 |
Posted: 12 Oct 2026 at 9:16am |
Seems like you have eliminated the master cyl and the trapped air..........
--------- What Causes a Complete Loss of Brake Power? If your brake pedal drops straight to the floor or you lose all stopping power, the problem is not a bad ABS. A total loss of brakes is usually caused by:
Posted: 12 Oct 2026 at 9:20am |
Maybe pull the ABS fuse and then test it... When you start the car, the ELECTRICIAL to the ABS is ON.. When you are pumping the pedal with engine off, NO ABS..
----------- Yes, the ABS (Anti-lock Braking System) valves in a car are electrically controlled, even though they manage hydraulic brake fluid. How It Works
Edited by steve(ill) - 12 Oct 2026 at 9:20am |
bobkyllo
Posted: 12 Oct 2026 at 10:39am |
One other thing that comes to mind.
Push rod length? Is it possible that could be off so far to give me this trouble? Seems odd that 2 cylinders would both be that far out of adjustment. I. Haven't adjusted a push rod in ages. I will give the fuse a try. I just hate to give up but it gets to a point how much time can I afford to put into this |
Posted: 12 Oct 2026 at 1:36pm |
master cylinder and trapped air are both "old school problems"... normally an easy fix... thats why i suggest looking more into the ABS... it can have more Hidden problems.. and you apparently had some problem BEFORE you changed the Master. ... but checking the rod stroke is a good idea.. should be able to compare the OLD master to the NEW if you still have it..
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5025 |
Posted: 13 Oct 2026 at 2:29pm |
Niegbhor had 72 Chev C20 4x4 truck, the first year with front disc brakes. Somewhere around 2000 he was replacing rotors and pads on the front brakes as I stopped to visit about something. Complaining about the how hard they were to bleed. So he had gotten a power bleeder. Not many years later he retired, I bought the old pickup. A few more years go by one of the rubber brake lines breaks. I was having trouble getting the air out. Called my friend that just has touch with repairs, always goes faster with his help. Just has much better mechanics brain than I do. He takes one look, why do you have the bleeder valve on bottom? Never entered my mind to thing about. On that truck brake assembly fits ether side, but the bleeder hole are only drilled on one, so right and left are different. Some how the by now dead previous owner had gotten them bleed and they worked for years. But much easier to work with the earths forces and let air rise to eascape.
Maybe something you're not thinking of like me as you stare at it. I have never gotten into the ABS stuff. Please come with answer when it is fixed.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11133 |
Posted: 13 Oct 2026 at 6:24pm |
My sisters Edge did that. Turned out to be the ABS solenoid. Like to never found one. I think just shy of a thousand dollars complete.
Posted: 13 Oct 2026 at 6:35pm |
yea, i thought to pull the fuse and turn the ABS OFF... but if the valve failed in the wrong position and leaks thru... that might not work..
Tbone95
Posted: 14 Oct 2026 at 6:49am |
I’d like to say that I’ve never heard of that. But I, ummm, err, uh, “know” someone who did that 🙄 |
Ray54
Posted: 14 Oct 2026 at 11:14am |
Just proves in my case I am a competent parts changer, but not a true "gear head".
I will not ask about "that other guy" would not want to hurt anyone's feelings.![]() |
Tbone95
Posted: 15 Oct 2026 at 9:08am |
jvin248
Posted: 15 Oct 2026 at 11:00pm |
Look for computer module reset procedures. 2014 Ford fusion AWD I must go through a brake release series of magic button presses and after new pads/rotors I have to energize the system with more magic button sequences. Electronic parking brake system is the root of that system gyration. Yours as a 2013 may have a similar system. . |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36766 |
Posted: 16 Oct 2026 at 5:38am |
Voodoo Electronics to force return to dealers or Auto Shops trained in this crap.
Saw this begin in the early 80s with Truck ABS moving into cars and lighter machines. After 2016 Harleys have a common brake control from either hand or foot control either operates BOTH fr and rr brakes, bleeding those now sucks. Magic Modules to protect the auto owners, not really but is how is sold. Only protects the idiots behind the wheel that still drive into objects as are not paying attention to DRIVING, or are overly attentive strictly to Driving and not monitoring the conditions, traffic, approaching or leading machines. All the ABS Traction Control and electronic auto functions on Earth have yet to preclude an accident where some systems are not one time ever challenged by Drivers in life of a vehicle. |
wjohn
Posted: 17 Oct 2026 at 10:04am |
Have you talked to a Ford dealer yet? I had a buddy that had a 2013 or 14 Edge and he had some really weird brake issues at one point, and as I recall there ended up being a Ford service bulletin on it. Ford might have even paid for the parts but not the labor, or something along those lines (out of warranty period but noted as a known issue).
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4260 |
Posted: 17 Oct 2026 at 10:51am |
may have to reset relearn the abs with your scan tool
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 403 |
Posted: 17 Oct 2026 at 12:16pm |
Just my 2 cents, but I have never tested a vehicle with ABS and hydraulic brakes that will pass a DOT brake test(pump pedal 3 times, hold it down for 5 seconds and it shouldn't sink). At work we have vehicles from Ford, GM and RAM. None of them will pass that test, and all of them will let the brake pedal sink to the floor over about ten seconds, and they have been like that since new. I have been told to not press so hard on the brake pedal. I assume it has something to do with the ABS module, and my guess is yours has failed in some capacity. The job of the ABS is to reduce the line pressure to stop a skid, so it has to have a place to move fluid to where it can be pushed back into the system when the brakes are released, and it has to push that fluid back without electricity or a blown ABS fuse could cause a complete brake failure. It is not a cheap item to replace, so you want to be sure it is bad before you spend the money on it. I think I would cap the outlet ports at the master cylinder and see if it will hold pressure first, then with those hooked back up I would cap the outlets of the ABS module and see if it holds pressure there. That should get you closer to solving your issue. Caps and plugs are available, make sure you find the correct size.
Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
HudCo
Posted: 17 Oct 2026 at 6:50pm |
also check to see if your wheel speed sensor are reading and reacting correct
bobkyllo
Posted: 22 Oct 2026 at 6:45pm |
Bad news for the customer. They have to get it towed to a shop that can program the abs module. I thought i could find a mobile programmer but no luck. The abs has failed internally.
Posted: 22 Oct 2026 at 9:00pm |
unpluggin the fuse has no effect ?
