Finally have 149 in CA |
1955allisca
Topic: Finally have 149 in CAPosted: 20 Jan 2015 at 9:58pm |
Just have a few issues, first whenever ya let out on clutch under a load the throttle surges i believe it just needs a new gov spring but any input would be great. Also put a new button clutch from dennys carb shop in. The clutch never slipped before i just didn't want to have to take engine out again later. So now the clutch button clutch slips whenever its ib third gear it and i pull brakes it jusf bogs engine down to a point then does nothing, hand clutch had never slilpped before. do you think it could be habd clutch or pressure plate springs?
Posted: 20 Jan 2015 at 10:07pm |
If the PTO shaft keeps turning when the tractor stops moving, it's the HAND clutch that is slipping. I doubt it's the foot clutch if you have a 4-button style.
1955allisca
Posted: 20 Jan 2015 at 10:14pm |
Only problem is i took the PTO off a long time ago haha any other ideas on how to test? It is 4 button type
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7726 |
Posted: 20 Jan 2015 at 10:24pm |
Do you have an anti surge spring on the rod going from the governor to the carb? IF not, that is what is causing your surging issue. AGCO still carries them. Attach one end to a hole in middle of the rod and hook the other end to one of the manifold studs above it.
1955allisca
Posted: 21 Jan 2015 at 5:54am |
It still has it but its not hooked up ill try that thanks
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6386 |
Posted: 21 Jan 2015 at 6:24am |
I took my hand clutch out as it slipped when pulling. Everyone I talked to said they rarely hold up under that much load.
I used the opposite side shaft and drum.
Charlie
1955allisca
Posted: 21 Jan 2015 at 7:29am |
Is it possible to use shaft from C?
1955allisca
Posted: 21 Jan 2015 at 7:39am |
I'm thinkin its hand clutch because it spun left wheel in 3rd gear then when i pulled left brake to get the right to spin one of the clutches slipped that sounds like it happened when i tried to put a load n that axle and i got that right axle with the clutch slippin.
Pipe
Posted: 21 Jan 2015 at 9:58am |
Shaft from a c will not work you need a axle from the left side of a Ca.
Pipe
Posted: 21 Jan 2015 at 10:01am |
If you need a axle I got a whole rear end I would sell $150.00 in Mi. hour north of border.
1955allisca
Posted: 21 Jan 2015 at 11:13am |
This tractor is basically an expirement to prove you can build a good tractor for less than $750 so i think just to keep things cheap I'm gunna bolt the clutch together or weld it has anyone had problems with this?
Charlie175
Posted: 21 Jan 2015 at 11:16am |
Doing that messes it up for putting it back to stock.
I think I paid $75 for my shaft.
Charlie
1955allisca
Posted: 21 Jan 2015 at 11:21am |
This tractor is too rough and too far gone to ever be put back to stock i cut off or took off anything that wasn't necessary for making it run to make it lighter so I'm not worried bout puttin it back to stock i bought it for $300. in.a.fence row and sold the parts i took off for $200
1955allisca
Posted: 22 Jan 2015 at 7:34pm |
I bolted hand clutch and still slips with brand new clutch but it still has stock pressure plate springs so i assume that is all that an be wrong with it, does anyone know where i can get tougher springs for one?
1955allisca
Posted: 22 Jan 2015 at 7:36pm |
Thanks for the info about that governor surge spring it runs great now
Peterson
Joined: 05 Mar 2011 Location: Westboro, Wi Points: 875 |
Posted: 22 Jan 2015 at 7:48pm |
Have your clutch man put in the lavender colored clutch springs. Should hold with them in.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
1955allisca
Posted: 22 Jan 2015 at 8:12pm |
I don't have a clutch man, i am 17 and work on my own stuff i have built the tractor by myself from day one. Where would i order stiffer springs for it?
Peterson
Posted: 22 Jan 2015 at 8:15pm |
Look up hy-capacity clutches. Idk if they sell to individuals or not, but im sure they could tell ya who your closest dealer is for them.
1955allisca
Posted: 22 Jan 2015 at 9:10pm |
I have heard of putting smaller springs inside of the existing springs has anyone tried that?
Posted: 22 Jan 2015 at 9:29pm |
Your hand clutch is your problem. Get rid of it, or figure out how to maybe (somehow) bolt it solid. Maybe there's a way to drill one hole clear thru the pressure plates and the disc so it cannot ever slip.
1955allisca
Posted: 22 Jan 2015 at 9:36pm |
I drilled through it and put 3 bolts in it and button clutch slips so springs are the only thing it could be i just would like to make springs stiffer where would i purchase stiffer springs or kits to beef them up?
Posted: 22 Jan 2015 at 9:43pm |
A 5/8" or 3/4" lock washer down inside of each spring cup will stiffen your existing springs. Clamp the lock washer in a vise and take the twist out of it so it lays flat.
1955allisca
Posted: 22 Jan 2015 at 9:55pm |
I have heard that, will one work or a couple or 3 of them?
Posted: 22 Jan 2015 at 10:00pm |
One in every spring cup would be a nice start. You can add too many, so that the clutch won't even release. How many springs does it have ..6???
1955allisca
Posted: 22 Jan 2015 at 10:06pm |
Yes it has 6 springs, i already have the engine in now and will have to take it out to put washers in the pressure plate and don't want to do that a couple times haha. Will one washer make the difference or should i go ahead and put 2? Also will i have to adjust the fingers?
Posted: 22 Jan 2015 at 10:13pm |
You may have to adjust the fingers to get the pressure plate torn apart, so yes you might have to adjust them when reassembling. If you drop in two shims, the springs cannot be collapsed when you bolt the pressure plate back onto the flywheel. There has to be some small gap between each coil to be able to release.
1955allisca
Posted: 23 Jan 2015 at 6:54am |
Okay thanks
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5475 |
Posted: 23 Jan 2015 at 6:36pm |
I heard from many others that Denny's Carb shop is quick to take your money and slow to give any help if things aren't right, Just a thought. As for the axle clutch, if it's rebuilt right it will hold more that a stock 149 can ever do. I've done many of them and can stall whatever power is out front. But for a pulling tractor just put in a LH shaft and loose the weight of the clutch pack.
