Exhaust rule question
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust rule question
    Posted: 26 Aug 2012 at 1:20pm
  This may be a dumb question to some of you, but I can't figure it out. I was reading the rules to an organization and all the diesel classes have this rule. Could someone explain it?
Exhaust will have 2- 5/16" bolts as close to the elbow as possible at a 90 degree angle from each other and no more than two inches apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 1:50pm
The bolts are to stop or slow down turbo parts if one should fly apart, without causeing an exhaust block of too much
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 4:49pm
Around here they also have a no curved stack rule. Should anything fly out, it will go up and not out into the spectators, for about the same reasons.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 12:45pm
Correct, they are there to stop the exhaust wheel from coming out of the stack. I have the elbow off our D-21 where the exhaust wheel came apart. Went straight back and chewed straight through the elbow and bounced about the engine compartment.
Making a living farming with and working on Allis Equipment
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 12:55pm
So they bolt all the way through the exhaust and form an X inside?
allis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis180 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 1:16pm
Exactly.
This page was generated in 0.049 seconds.
