Deck L-Bracket for 616 Hydro
GovernorJason View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GovernorJason Quote  Post ReplyReply Direct Link To This Post Topic: Deck L-Bracket for 616 Hydro
    Posted: 09 Oct 2016 at 5:47pm
It appears that the L-shaped bracket that connects the rear of the mower deck and the roller bar has broken in half.  Two questions, what is the proper term for this part and secondly, is there any place that anyone knows of where I can purchase one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 6:34am
Can you have it welded? Take it to a welder and see if he can run a bead on it. He might be able to fix ya right up.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:28pm
I sent you this link via a private message.
Here it is again
www.http://bsintek.basco/MDEZResultPages/default.aspx
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote GovernorJason Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 9:00am
I appreciate the feedback, I tried that link and for some reason it will not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 9:11am
Call the gals at Sandy Lake (vendor listed on this site) and they can send you parts break down of your model. Once verified on part needed, they are pretty darn good at finding what you need for the older units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 11:32pm
If you are unable to use the address, just do a search for "bsintek". That should find the site for you. I use that link all the time.
You must enter 1691032 into the search box. It is a Simplicity site and will not except the Allis numbers. The Simplicity model is a 5216H. LOL Bob
