Dash light 7060
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Dash light 7060
    Posted: 17 Oct 2026 at 1:21pm
Where is the, transmission pressure below 1800 RPMR, sensor located? I am tracing a no light on the dash. It has power to the bulb but no ground.
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 2:59pm
Found a brown with white stripe unplugged under the cab below the brake
Pedals, works now. Does anybody know where they ground the wiring harness from the cab? Just want to clean that up since its open.
Edited by whatscooking - 17 Oct 2026 at 6:02pm
68 D21 81 7060
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 8:38pm
Swing the top battery tray out on the right hand side. There should be a wire that goes from the bottom of the cab to the side of the transmission, where the battery grounds attach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 8:24am
I saw a grounding strap going from the cab over to the battery ground at the transmission, it looks like it needs attention. Where is the ground wire for the guages come out. It's tight quarters where that ground strap hooks to ground the cab.
68 D21 81 7060
