D19 Lift arms wont stay up
Buddy2366 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buddy2366 Quote  Post ReplyReply Direct Link To This Post Topic: D19 Lift arms wont stay up
    Posted: Yesterday at 8:00am
D19 gas, serial#15090, lift arms raise plow, as soon as valve is returned to hold posttion, lift arms drop. I removed 4 bolts from top and 2 from bottom of valve stack and removed and checked ball and seat/spring. O ring around assymbly looked ok. Did not detect visually any obstruction/foreign material under ball/seat. Cleaned with carb cleaner. re-installed valve stack, same result. Where do I look from here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:02pm
That check ball and spring (between the upper half and lower half of the valve) is only part of it. The poppet on the opposite side of the ball/spring has a seat made into it and it seals against the seat made into the upper casting. I don't know if you could use some lapping compound and get the two parts to like each other or not. Be sure to replace that Oring regardless. I wish Mack could answer your question. D-19's are somewhat known for this. A stiffer spring wouldn't hurt.
