D19 Lift arms wont stay up |
Buddy2366
Topic: D19 Lift arms wont stay upPosted: 1 hour 24 minutes ago at 8:00am |
D19 gas, serial#15090, lift arms raise plow, as soon as valve is returned to hold posttion, lift arms drop. I removed 4 bolts from top and 2 from bottom of valve stack and removed and checked ball and seat/spring. O ring around assymbly looked ok. Did not detect visually any obstruction/foreign material under ball/seat. Cleaned with carb cleaner. re-installed valve stack, same result. Where do I look from here?
