D19 Gas possible governor surge? |
Buddy2366
Topic: D19 Gas possible governor surge?Posted: 11 Oct 2026 at 7:48pm |
Have been getting some time in the furrow with my D19 Gas pulling a series 70 SC set on 5-14"s. Tractor was overhauled from the bell housing froward this past spring. It was handling the plow real well imho from the getgo. Plow was not scoured and hadnt turned a furrow in a long time. Tractor ran fine plowing in third gear making 6 passes about 100 yards long. Got dark and put it back in the shed. 2 days later, resumed plowing in a different field making passes about 1/8 mile long each. after 2 rounds tractor starts to sound like the governor was causing a surge in rpm at WOT. Got out the service manual and tried to adjust out the rpm surge per instructions. Set low and high rpm's and then turned in the anti-surge screw till I raised the high idle to 2300. Went back to the field and made another pass, but the adjustment I made did not help much at all, tractor still experienced high/low engine rpm's. Hopefully the video will load. Any advice is appreciated!uploads/24926/IMG_0592.jpeg
Edit: Video is too big to load Edited by Buddy2366 - 11 Oct 2026 at 7:55pm |
D171958
Posted: 11 Oct 2026 at 10:38pm |
My d17 was doing that earlier this year and it turned out a jet in the carburetor was plugged may be the same problem the Dr would know he helped me with mine probably a fuel issue though
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9264 |
Posted: 11 Oct 2026 at 11:01pm |
I was thinking as I read that it sounds like a fuel mixture problem as it was fine just the day before.
Posted: 12 Oct 2026 at 5:45pm |
I would agree with the carburetor/fuel mixture possibility. The engine has to perform perfectly for the governor to work properly. Just open the main just a couple of turns and that should give you a clue as to whether that is causing your surging or not. Now as far as governor surging problems on a D-19 gas engine ?? Yeah. They are pretty notorious for that. For myself, I have always avoided using that surge screw as much as possible. My reasons for that are (just like a D-15) using the surge screw makes the governor very "dead" in the slower RPM ranges. I've always gotten by just fine by being patient (really patient with the D-19) and shortening the link rod from the governor cross arm and the carburetor a couple of turns at a time until the surge subsided. Good luck. You'll get it.
Buddy2366
Posted: 12 Oct 2026 at 8:47pm |
Thanks for the replies!
Doc, I've got a decent video I'll email to you where you can hear the engine running. My carburetor Man suggested opening the gas main as well. Carb was boiled out clean and rebuilt, Gas tank is clean as well as new sediment bowl and screen. I take it I should back the anti surge screw back out to where the engine rpm at WOT is approx 2250? That's where it was was before this started. Man that engine was running sweet! D19 has beet juice in rears, 300lb on each rear and a stack of 4 on the front end. Running regular 87 octane non-ethanol gas. Had my carb guy install a pyrometer in manifold. 3rd gear at 2250rpm and she was at 1350-1400 deg.
Posted: 13 Oct 2026 at 11:39am |
Pretty sure that 1400 degree number glows in the dark on the manifold.
