d17 lift parts
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: d17 lift parts
    Posted: 22 Sep 2026 at 6:26pm
any one have one of these kits on their d-17 or have those parts to measure or purchase , i would like to see what they look like installed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 6:33pm
I have a D-14 with one of those bolt-on arms. Be kind of hard to measure but the center-to-center length I could do. Hyd cylinders are just WD tractor rams I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 8:29pm
dr. how much differance do you think it would make  it should allready lift enought to lift the front wheels off the ground on my diesel tractor .    i am sure that i would not find a setup to buy  but it would be very easy to fab with a picture of that all installed  and some center to ceter mesurements    i would have to think that it would lift enought break things if the common sense whent out the window
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 10:04pm
I know this: a series 3 model has a little larger diameter lift cylinder inside the rear end versus the early model D-17's. If the unloader valve on the OEM hydraulic pump was adjusted to 3500 to 3700 psi, I can't imagine why anyone would have needed any more lifting power. Also with that add-on kit, the lifting time would be slower, like maybe 5 seconds.
KP4620 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP4620 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 6:07am
Yes I have a series 1 with that kit on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 6:19am
The butt end of those lift cylinder brackets are attached to the bottom of the platforms, correct ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote KP4620 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 7:25am
Yes, it bolts to the bottom of the platform ,with the brace bolted to the inside of the fender bracket. Not sure the cylinders are the same as a WD but they are close.
