D17 head gasket leak
Putnamd17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Topic: D17 head gasket leak
    Posted: 1 hour 22 minutes ago at 6:24am
After rebuilding the engine and having the head redone, it was cut flat and the whole works, I tightened Down the head in the order in the book and when I was adding coolant I was getting a pretty good leak along the entire side of the manifold, I got the rebuild kit from reliance, did I do something wrong in the rebuild or are there common issues with those gaskets? I have another head gasket that is metal instead of the composite, would this be better?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 18 minutes ago at 6:28am
Did you coat the gasket with anything like coppercoat?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 14 minutes ago at 6:32am
You had the head milled flat but how is the block deck and sleeve standout?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 12 minutes ago at 6:34am
Sleeve standout measured within tolerance of what the book states, I didn’t use any sealer with the composite gasket I have some of the copper sealer that comes in a spray can
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 11 minutes ago at 6:35am
Are you sure it's the head gasket, or could it be coming out of a manifold stud?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 56 minutes ago at 6:50am
Those gaskets (of any type) MUST be coated with something or they will leak. Some may argue about this, but after 50+ years of never ever having to redo a leaker, I think I'm right. Run a thread tap down every head bolt hole and blow out the rust/dirt. Wire brush off the head bolt threads clean and wipe some grease on the threads. Re-torque head bolt COLD after 2 to 4 hrs of run time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Putnamd17 Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 6:52am
Ok thank you, which head gasket would you use and which sealant?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 47 minutes ago at 6:59am
I use a product called "Hylomar" sealer around the outside and around every water jacket and oil passage hole on both sides of the gasket. Copper Coat should be OK fine. Just paint it at least one good coat and then a second coat and assemble while tacky. I don't care which type of gasket. They all will work AND seep coolant if not coated with something. I might even reuse the gasket you have but I'm not there looking at it either. Wipe and air dry the block and head with brake kleen on a rag to be clean.
