D17/170/175 Final Drives |
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Topic: D17/170/175 Final DrivesPosted: 30 Dec 2025 at 2:36pm |
Just curious, was thinking of changing the final drives on my 185 LLSS build to the faster D17/170/175 final drives. I understand that they are not as wide. Would they be strong enough, is my question? Thoughts for a snowy, wintery day like today....lol.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3741 |
Posted: 30 Dec 2025 at 2:47pm |
70251775 is the same on 180/185/175 70237058 is the other pinion D17/170
and 70247872 / 70237059 are the bull gears for 185 / D17
KevinON
Posted: 30 Dec 2025 at 2:56pm |
So by that I should be changing the pinion shaft?
Posted: 30 Dec 2025 at 6:37pm |
175-180-185 final drives are identical and are the widest/strongest final drives at 5.85 to 1 ratio. D-17 S3 and S4 and 170's are all the same strength/width and 5.43 to 1 ratio, for a 7% speed-up. Change the whole axle/final drive assembly !! How much HP they will take ??? I know of one tractor that has run one season at probably 350-400 HP without issues. Keeping under 7,000 lbs will help. The lighter the better. The less bar height on your tires is also good. LLSS class?? I wouldn't even think about it.
KevinON
Thanks(1)
Posted: 30 Dec 2025 at 7:46pm |
Thanks Dr. I will stick with the 185 finals then.
