D14 "popping" when shut off |
BOH
Joined: 03 Aug 2026 Location: Phillips WI Points: 3 |
Topic: D14 "popping" when shut offPosted: 03 Aug 2026 at 3:10pm |
My D14 just started popping once or twice when I shut her off. I am brush hogging just like I always do this time of year. Brush Hogging going well...plenty of power and no hesitation when working. It DID stall twice this morning when I let the clutch out
before she got warmed up. Thanks In Advance
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5459 |
Posted: 03 Aug 2026 at 3:22pm |
Let it idle for a bit. Is the idle set properly low enough?
Joined: 11 Sep 2009 Location: illinois Points: 93314 |
Posted: 03 Aug 2026 at 3:54pm |
yep... if it is worked hard and REALLY HOT, they will try to diesel when shut off... get the low idle down, cool off for a minute, should do it.
BOH
Posted: 03 Aug 2026 at 4:00pm |
Thanks for the reply! I didn't let her idle tooo long, just enough to get all the load off the tractor check the gauges etc. I am cutting an old hayfield, so it ran without any real load, just came to the house about 1/4 mile. I wonder if I need to richen the mixture a bit maybe on the idle side.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5690 |
Posted: 04 Aug 2026 at 4:53pm |
Both of their replies are correct. Richening the mixture will only make it worse. I always do a cool down idle for at least a minute before shutting any of my tractors down. 2 minutes for my diesels.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1663 |
Posted: 04 Aug 2026 at 4:57pm |
Make sure your timing is correct. And yes let it idle a bit. If all else fails shut if off in high gear and let clutch out a bit.
