D10
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: D10
    Posted: 04 Apr 2019 at 9:17pm
Is there much difference between a 61 model and the later model's?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2019 at 11:16pm
I don't have documentation to prove my comment here but some time back someone said that the early D10's and D12's had the 138 cu. in. engine but that in later models the 149 cu. in. engine was used, the same as in the D14's and early D15's.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 5:48am
Can be a lot of differences. I can better help if I had your D-10 serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 2:23pm
Original engine, used until 1961. The 138.7 ci [2.3 L]
The larger, 149 cubic inch, engine was introduced at serial number 3501 in 1961.
HTHs
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 4:30pm
One big difference, if I am remembering correctly, is that the early ones (Series I) also did not have any live PTO, but I think maybe by the series II's they did. That's one of the reasons the later ones can be a worth a whole lot more.
Also, The series III's had a hi-lo option for the transmission. I don't think a factory 3 point hitch would have been an available option either until at least the series II's came out?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 5:00pm
S/N all D10s;  1001-10100, Total Production: 5308
1959 - 1961: G138,  Total production with G138, 2148 approx.
D10 G149.  Production years G149, 1961 - 1968
Total with G149, 3160 approx.
The series I and II are basically the same with the exception of the engine.  Series III started at S/N 9001.  The series III offered an optional 2 range transmission.  The lights were mounted on the rear fenders.
There are a few changes n the tin throughout production.
Data provided by: "Allis Chalmers Farm Tractors and Crawlers Data Book"  Author: Terry Dean. Copy Rite: 2000.
If you need any other info just post what you need.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 1:06pm
There was a change mid-1961 that carried through to Series II. The engine was changed as previously discussed and the old WD/CA style hydraulics were eliminated in favor of a gear type hydraulic pump at the rear of the tractor run by a quill shaft through the clutch. The quill shaft design gave the D10/12 true independent hydraulics and PTO.
There was no form of independent PTO on the Series I and early 1961 models. Some had independent hydraulics (without traction booster) if they had the engine mounted hydraulic pump.
The 1961 changes started with D10 SN 3501 and D12 3001.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2019 at 6:59pm
The CA had the hand clutch. The D10/12 initially had no similar capability?
If true, was the early D10/12 a step backward?
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 10:56am
Yes, the early D10/12 had no way to stop the tractor and keep the PTO running. Step on the clutch and you also lost the hydraulics if it had the WD/CA type pump.
This page was generated in 0.116 seconds.
