custom pistons
JamesP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesP Quote  Post ReplyReply Direct Link To This Post Topic: custom pistons
    Posted: 18 May 2023 at 4:08am
Any suggestions on where to get pistons made? Model UC, thanks
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 7:37am
Not sure they can make all pistons, but EGGE makes some custom pistons for really old engines.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 8:17am
I spoke with Dan Karpel @ Crank Machine service a few years ago about pistons for a UC after he did a crank for me and he had a source.  He suggested making a fiberglass resin cast of the head chamber to give most accurate shape for best dome configuration.  Life has gotten in the way and i have yet to do it. Id be interested in doubling your order depending on what you go with, if you decide to roll with it.  I guess we have talked this over James,  but dont remember if i ever got you the contact info
Edited by CAL(KS) - 18 May 2023 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamesP Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2023 at 3:37pm
Hey Cal, I am sending one of my pistons to extreme tractor parts-Ray.
I ended up having my sleeves bored .030 over. I am having  .500 added to
compression ht. This will be 7-1 CR and the piston will be  .060 below the
spark plug hole so it wont require any features on top. Calculates show hp
around 65. Plenty for me, I am not competing just want enough that it never
powers out on the fun pulls and I can still hand crank it-- LOL.
I am only guessing but with your stroke, it would push the piston up enough to
gain a lot more compression plus CI. You could buy new sleeves and rings and
run stock pistons.??
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:37am
  Check Ross,  and Diamond.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 7:35am
  yeah i have to run short bbc style piston just to keep the rings in the sleeve with the stroke and custom rods i have.  Was going to run 4.625 bore as can be done without machine work on block, so will be 445 cubes if i ever get it done.  being a UM engine im in uncharted territory but i dont really have the finances to be a guinea pig lol.   if im going to do something i just as well make it a worth while though....
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 9:52am
Can help with custom pistons.
Dan Karpel
