Copper head gasket sealer
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: Copper head gasket sealer
    Posted: 26 Jan 2022 at 5:39pm
  What do you guys use for copper head gasket sealer?   I used Permatex copper sealer and it was gone, except for hints of it directly under head bolts where the most squish was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 6:27pm
The engines that I've had copper head gaskets on, I've used O-rings to seal the water and oil passages and fire rings on top of the sleeves. Nothing on the copper gasket itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2022 at 7:16pm
  Yep, fire rings on sleeves, since there are no grooves for o-rings, dont they get smashed down to nothing?
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 4:28am
I have used coper coat at the most and that’s it. Chances of it seeping a liquid are high
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 6:11am
The holes in my copper gaskets are large enough that the O-ring set inside of the gasket and when using a .090 gasket with .125 O-rings they squash down to .090
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 6:35am
Hylomar rubbed all over the copper gasket on both sides is about all you can do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 8:38am
  Yep duh, I guess I had it in my head about the pushrod holes, close to the edge of block, hate leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2022 at 8:39am
   Sigh, hate leaks.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2022 at 7:23pm
3m Black urethane winsheild sealer
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 8:59am
   Have you used this, if so do you have to pry head off because its good and sticky???
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2022 at 7:39pm
Defiantlyput o ring on sleave, I make my sleaves with o-ring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2022 at 7:40pm
I TURN o ring right on top. .015
OldAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2022 at 8:02am
I've always done the old trick of aluminum paint on headgaskets. I honestly think it prevents leakage better then copper coat - taken apart many things with copper coat that weeped - clean it up and use aluminum engine paint on the used gasket, put it back together and no issues.
This page was generated in 0.083 seconds.
