Compatible Wheels
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Compatible Wheels
    Posted: 12 Sep 2012 at 7:28pm
What makes of wheels are compatible with Allis tractors (B/C/WD/D series)?
Just getting ideas on what to be on the look out for if I wanted to go to taller wheels
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 7:15pm
Pretty much any 34 or 38 inch rear wheel center from an M-F or Ford will fit a WD-WD45-D17 without much difficulty.....8 bolt pattern is an 8 bolt pattern.
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 3:52pm
anyone on this forum make the centers to weld in to diffrent wheels. or have the pattern
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 9:30pm
Try this guy. He custom makes rear centers in 6 8 or 9 bolt patern. And I think there really light. Talked to him At Sigourney Iowa. He had his massy 101 there with his rim design. excellent work on them. hope this pic works.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 8:52am
most ford wheels have the right bolt pattern but the center hole is 5.5 and will need to be opened up another half inch to fit a wd . john deere 9 bolt dual wheels work good with 8 to nine adapters but the wd flange will need to be tapped to 5/8 or expect high dollar charge for the allen machine screws in nonstandard oem size. you can go back in the archives where i was talking about the cost of the screws to do a wd45 diesel rear where the owner didnt want to open the wheel flange up to 5/8 bolts.
Edited by mlpankey - 24 Sep 2012 at 8:59am
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2012 at 11:17am
Any wheels that will direct bolt on a wc?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2012 at 1:06pm
the pic of the wheels above that were on a massey 101, the guys name i believe that owns it is Zack Peterson. He has a pulling guide that has alot of usually in for and emails a newsletter ever month, i suggest looking it up at Antique Tractor Pull Guide!
