CA Valve Spring Specs
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Valve Spring Specs
    Posted: 8 hours 41 minutes ago at 1:11pm
Ive finally gotten around to diagnosing the misfire issue. Im measuring valve spring tension and none seem to be as expected. The stongest one is 55psi and one was only 35psi. The head rebuild was supposed to take care of that. Ill measure again after i research my technique...i bought an on head tool. It seems easy enough to use. I & T says 55-65psi to 1 5/16". One source says 70 psi but none approach that.
Edited by dfwallis - 7 hours 53 minutes ago at 1:59pm
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 26 minutes ago at 8:26pm
Appears that the tool cant accommodate the wide rocker pushrod to valve spacing. Ive enquired to the manufacturer if additional spacer inserts are available. Unfortunately, i think that will make the readings worse not better...lever arm pivet point is presently behind the valve which means it requires more force to compress the spring
