CA no oil pressure! |
Page <1 2345> |
Joined: 11 Sep 2009 Location: illinois Points: 93381 |
Posted: 06 Sep 2022 at 8:26am |
look at the intake valve... when it closes, you are coming up on compression... about 90 degrees you will be at TDC.. ( center) .. you will also hear the SNAP !! .... Adjust the valves on that cylinder that just came to TDC ............Should be about .015 inch clearance between the valve top and the adjust screw above it.
Rotate the motor 180 degrees and look for the NEXT cylinder to come to TDC... should be in 1-2-4-3 order ..... you can start at any cylinder ,, ( ex 4-3-1-2 )
84 prospector
Joined: 30 Aug 2022 Location: California Points: 65 |
Posted: 06 Sep 2022 at 8:35am |
This is done while it is cold right?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9240 |
Posted: 06 Sep 2022 at 1:06pm |
Rule of thumb is .002 more cold than hot (book). More likely to have even adjustment cold. Hot begins cooling the moment you start and unless you are proficient and experienced it may well get away from you.
Posted: 06 Sep 2022 at 4:02pm |
Steve is right... .002 MORE if your setting cold.... Book actually says .010 HOT for B and C.. ........ but .012 HOT for CA ?????? YOUR CHOICE !
![]() TOO tight is bad... A couple thousands loose is not a deal breaker.
84 prospector
Posted: 06 Sep 2022 at 6:37pm |
I should be good at .015 right?
84 prospector
Posted: 06 Sep 2022 at 6:38pm |
Or will it make that big of a difference to go .014
Posted: 06 Sep 2022 at 7:12pm |
No.... your fine... 1 - 2 thousandths LOOSE does not hurt.
84 prospector
Posted: 06 Sep 2022 at 7:20pm |
Kinda a dumb question but where can I spin the engine by hand? The crank pulley is too hard to grip by hand and spin
Edited by 84 prospector - 06 Sep 2022 at 7:23pm |
Posted: 06 Sep 2022 at 7:52pm |
there is a round hole in the radiator wrap around a couple inches below the grill... That looks at the crank shaft pulley front end.... There is a "hand crank" that goes into that hole.. Basically a 5/8 inch rod with a TEE on the end to engage the tangs on the pulley...
you might also be able to engage the PTO shaft and turn it with a pipe wrench and roll over the motor... It is about 3 to 1 ratio ... put the transmission in neutral.... IGNITION OFF...... or plugs removed. --------------------------------- basically the hand crank has something like a 1/4 inch roll pin about 1-1/2 inch long ( im guessing) that grabs the inside of the pulley.. Edited by steve(ill) - 06 Sep 2022 at 8:01pm |
84 prospector
Posted: 06 Sep 2022 at 8:27pm |
Ok thanks, just to be sure I’m doing this right, when I’m adjusting the #1 cylinder i rotate until either the exhaust or intake valve is completely closed (spring all the way up) and adjust that valve that is completely up to .015, then rotate the engine until the other valve is completely closed/ up and adjust that one to .015
Posted: 06 Sep 2022 at 8:34pm |
when #1 is at top dead center (CENTER)... both valves will be closed and BOTH can be adjusted.. Rotate 180 degrees and #2 will be ready... Rotate 180 degrees and #4... Rotate 180 degrees and #3 will be ready...... you adjust BOTH INTAKE and EXH when that cylinder is at TDC.... you can hear the SNAP telling you that you are at CENTER.
Intake - Compression -Power - Exhaust are the 4 strokes ....... when you see the INTAKE valve CLOSE, rotate about 180 degrees until you hear the SNAP for each cylinder. Edited by steve(ill) - 06 Sep 2022 at 8:37pm |
84 prospector
Posted: 06 Sep 2022 at 9:03pm |
I am not hearing any snap
Posted: 06 Sep 2022 at 9:38pm |
OOPS Im on the wrong post.. Yours is a CA with a DISTRIBUTOR.. NO SNAP... You will have to remove the spark plug and stick a wire inside the hole and feel for the piston at the top... Or after the INTAKE close, just turn more than 90 degrees and you should be close. OR... there is a 1 inch round hole in the side of the bell housing that is used to time the motor.. After the intake valve closes, have someone look in the hole as you ROTATE the motor and stop at the CENTER or TDC mark.
Edited by steve(ill) - 06 Sep 2022 at 9:45pm |
84 prospector
Posted: 06 Sep 2022 at 9:52pm |
Ok so whenever a cylinder is at tdc the two valves for that cylinder will be closed?
84 prospector
Posted: 06 Sep 2022 at 10:07pm |
I set them all at .015 and it is running a little better but is still backfiring out the exhaust. When I put a load on the engine going up a hill it smooths out completely.
Posted: 06 Sep 2022 at 10:40pm |
carburetor could be off a little..... tractor has been setting a long time... maybe just run a while and see if it BREAKS IN ??
backfire at low idle or high idle or both ?? ( when NOT under load) Edited by steve(ill) - 06 Sep 2022 at 10:42pm |
84 prospector
Posted: 06 Sep 2022 at 10:42pm |
I’m gonna go back through and double check all the valves are adjusted correctly tomorrow, and see how it runs again.
84 prospector
Posted: 06 Sep 2022 at 10:43pm |
It backfires at both, not so bad at idle more of a miss or small backfire
Posted: 06 Sep 2022 at 10:45pm |
sometimes a backfire is a sticky valve stem due to setting for years... Running a while can fix that... But you should also note that under load, i would think.
also remember the motor is 70 years old... Could be spark plugs , wires , coil slightly low on power , distributor cap crack or carbon tracked, carburetor not quite right, etc, etc... Edited by steve(ill) - 06 Sep 2022 at 10:48pm |
84 prospector
Posted: 06 Sep 2022 at 10:48pm |
I sprayed the valves down with wd 40 and watched to see if it looked like any were sticking and there weren’t any that I could see, I just put a brand new coil on it when I got the tractor, it was a standard ignition one I think. I haven’t replaced the plugs yet or the wires. It does run a little better with the choke on
Edited by 84 prospector - 06 Sep 2022 at 10:51pm |
Posted: 06 Sep 2022 at 10:51pm |
YEP....... a general tune up should be on the list in the future..
choke on is restricting the air inlet... That means your running out of fuel... Could be partly pluggage in the carb, restricted fuel filter . Edited by steve(ill) - 06 Sep 2022 at 10:53pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56116 |
Posted: 07 Sep 2022 at 4:42am |
Choke on runs better could also be air leak at choke shaft. Spray some solvent at the choke shaft(outside carb) if it sounds better briefly, there's your leak...
84 prospector
Posted: 08 Sep 2022 at 11:28pm |
Could it be backfiring because there isn’t enough back pressure? it is running basically open manifold right now. The previous owner set a pipe on top of the manifold and tied it down with bailing wire then slid a 90 degree angle pipe over that. It is not sealed to the manifold outlet, just set on top/ around it
Edited by 84 prospector - 09 Sep 2022 at 12:37am |
84 prospector
Posted: 08 Sep 2022 at 11:31pm |
Can I keep running it how the previous owner rigged it up? The tractor isn’t very loud so If I do need to fix that would I be safe to run a 3 foot straight stack on it?
Les Kerf
Posted: 09 Sep 2022 at 6:31am |
Yes and yes. The notion of needing 'backpressure' is utter nonsense. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5690 |
Posted: 09 Sep 2022 at 7:02am |
I use Seafoam in the crankcase if an engine has been sitting for a long period of time or if it smokes. Amazing product which cleans the entire engine internally including the valves and valve stems. Ive had engines that smoked bad, used Seafoam, and they not only stopped smoking but ran much better. Cleans the rings of carbon which make the rings seal as they should. Be prepared to perform 2 oil changes as the oil will be very black from all the crud.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5323 |
Posted: 09 Sep 2022 at 7:45am |
I'm not much for "snake oil", but Seafoam is amazing stuff. I always have a couple cans on the shelf.
84 prospector
Posted: 09 Sep 2022 at 8:36pm |
Ok I will just run it how it is. I just took the plug out of the transmission fill port and noticed it is not full, I can’t see any in the tube so what type of oil do I put in it? Just normal 80w90 gear oil?
84 prospector
Posted: 09 Sep 2022 at 9:18pm |
I saw somewhere 20w can be used In it and that there is supposed to be a hydraulic pump on it, I don’t see any hydraulic pump anywhere. I have a bunch of 5w30 can I put that in there? It kind of smells like gear oil on the inside of the plug, so could gear oil also be used?
84 prospector
Posted: 09 Sep 2022 at 9:34pm |
I stuck a peice of trimmer line down the hole and there is oil in it, just not full enough to see any. The oil that came up on the trimmer line has a orange yellow tint to it and the underside of the plug has a orange yellow tint.
Page <1 2345> |
